Old 07-20-2005, 04:34 PM   #1
tataat
tataat is on a distinguished road
Default Help: coolant temp sensor connector
Does anyone know which gauge should be used when crimping insulated wire connectors?
97 SL1 OEM parts
The wires on the connector are labeled as "0.35mm/GA22". However, 0.35mm=AWE27, AWE22=0.64mm.
Thanks.
Add to tataat's Reputation
Rate the quality of this post and help tataat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tataat is offline   Reply With Quote
Old 07-21-2005, 02:15 AM   #2
sierrap615
sierrap615's Avatar
Default Re: Help: coolant temp sensor connector
wiring for sensors(or basicly anything relating to the PCM) should be soldered, not crimped. anytime when you need a precise signal, crimping is not recommended.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 07-21-2005, 07:00 AM   #3
Sky King
Sky King's Avatar
Essentially, I agree. I actually have never been a fan of crimping. I have soldered all connections, whether for power, wires for trailer lights or speakers then use heat shrink for insulating the connection. However apparently Saturn feels crimping to be adequate because the replacement connector kit that they sell for the ECT sensor comes with two crimp butt splices that have heat shrink insulation on them which melts and seals the connection from moisture. I replaced my connector but I still soldered mine.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Coolant Temp Sensor? gr8gonzo0 S-Series Tech 2 05-12-2009 09:21 AM
Part number connector for coolant temperature sensor smp7015 S-Series Tech 8 03-08-2009 12:41 AM
Temp Sensor Connector Part # Dsell S-Series Tech 9 09-05-2008 07:44 PM
3.5 l coolant temp sensor DMVue Vue General 6 12-15-2007 09:17 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
