Old 04-16-2005, 09:13 AM   #1
staroffear
staroffear is on a distinguished road
1994 SC2
Default neutral safety switch
Where is the neutral safety switch located on a '94 Saturn SC2, and how do you replace it??
Add to staroffear's Reputation
Rate the quality of this post and help staroffear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
staroffear is offline
Old 04-16-2005, 11:14 AM   #2
Razorbak
Razorbak's Avatar
Default Re: neutral safety switch
The Park/Neutral Position Switch is attached to the rear side of the automatic transaxle case just above driver's side axle.
It must be installed very carefully or the internal part of the new switch could be damaged. It also requires adjustment when installed, using an ohmmeter or continuity tester to check for continuity across terminals on the switch, before tightening the switch to case bolts.
Add to Razorbak's Reputation
Razorbak is offline
Neutral safety switch help Highmile S-Series Tech 2 12-15-2009 02:15 PM
how to change neutral safety switch shur35 S-Series Tech 3 07-17-2009 11:06 PM
Neutral Safety Switch????? Clickety_Clack S-Series General 10 12-03-2008 10:24 PM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 08:55 AM
Neutral Safety Switch Marlin Liew S-Series Tech 7 11-04-2004 12:55 AM
