Old 03-17-2005, 08:37 AM   #1
hyattgl
hyattgl is on a distinguished road
Default '98 SL2 Persistent Rough Acceleration and Stalling
After my '98 SL2 warms up, it runs roughly and sometimes stalls when accelerating. I'm thinking of prying open my wallet and replacing the EGR, but I've been cleaning and changing parts in an effort to fix this for weeks. I'd really like to find and fix the real problem. Here's the sequence:
1 Symptoms: Started running roughly when accelerating, eventually started stalling
Attempted fix: Changed the spark plugs, plug wires, air filter, PCV and ECTS
Result: No effect
2 Attempted fix: Cleaned the EGR
Result: Ran like a fine Swiss watch. After 13 miles, SES lit up.
3 Symptoms: SES illuminated, car running great, pulled an OBDII code of P0341
Attempted fix: Checked plug wires, found and fixed one loose one. Reset PCM.
Result: Initially, SES still lit, but soon went out. Started stalling when warm again.
So I'm back where I started, with my SL2 running like crap. Having looked through this forum, I see more ideas of what I could do (clean the throttle body, replace the TPS, replace the fuel filter, clean or replace the coil packs), and I expect I'll do most of these. But none of those would seem to address the fact that my problem only comes when the engine is *warm*. It runs great when it's cold.
What is the problem?
Add to hyattgl's Reputation
Rate the quality of this post and help hyattgl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hyattgl is offline
Old 03-17-2005, 04:12 PM   #2
Razorbak
Razorbak's Avatar
Default Re: '98 SL2 Persistent Rough Acceleration and Stalling
Result: No effect
Since the EGR valve is supposed to remain closed when the engine is cold and at idle speed, I suspect your EGR valve is bad. It sounds like your EGR valve is sticking in the open position when warm, causing the rough idle, hesitation, and stalling...
http://autorepair.about.com/od/gener...l/bldef165.htm
Before you do that, though, you might as well clean out the throttle body and clean off any corrosion from the coil packs, because those are easy DIY repairs, and they're cheaper to implement than replacing the EGR valve.
Question: When you "cleaned the EGR", did you make sure that you could push the pintle plunger up and down easily without restriction before re-installing the valve?
Add to Razorbak's Reputation
Razorbak is offline
Old 03-18-2005, 09:05 AM   #3
hyattgl
That looks like a very useful site, and certainly the EGR entry helped my understand that widget. If you haven't guessed, I'm a newbie at this. I used to work on cars until computers and air pollution equipment intimidated me out of it...many, many years ago.
I'll do that, thank you.
Yes, although the pintle seemed to be moving freely even before I started cleaning. I wonder if that means I'm dealing with a bad solenoid. Then again, maybe I just didn't clean the EGR thoroughly enough. Having read a bunch of SaturnFans posts on the subject, I was afraid to let too much carb cleaner get up into the valve, toward the upper (electronic) part of the valve.
Thank you very much for your help, Razorbak.
- Glenn
hyattgl is offline
Old 03-18-2005, 09:58 AM   #4
Razorbak
Razorbak's Avatar
As long as you don't immerse the electronic part of the valve (the top half), you can clean to your heart's content on the bottom side. FWIW, when I cleaned my EGR valve, I just turned it upside down and filled the bowl that the pintle operates in with carb cleaner. Then I proceeded to scrub off all the carbon deposits from the pintle head and inside the bowl, and working the pintle up and down until it moved freely.
Razorbak is offline
Old 03-18-2005, 10:56 AM   #5
hyattgl
Excellent. Thank you, Razorbak. Those details are a very big help. I'll give the EGR a more rigorous cleaning over the weekend, as well as the throttle body and coil packs.
- Glenn
hyattgl is offline
'97 SL2 stalling and starting rough gr3atm3linko S-Series Tech 8 09-28-2009 12:27 AM
'97 SL2 intermittent stalling/running rough chopperdave S-Series Tech 5 10-16-2007 08:05 PM
Please help me fix my 92 SC, Rough Idle/Stalling lou_brakant S-Series Tech 7 08-18-2004 04:50 PM
Stalling During Acceleration ... sier Miscellaneous Tech 6 05-02-2004 02:54 AM
Rough Rider stalling on the slow down Fuerzan S-Series Tech 3 04-23-2001 12:07 PM
