Old 08-15-2016, 02:00 AM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default timing chain do pull chain after I turn crank 3 oclock
Do U leave old chain still on and turn both the cam and crank to 3 oclock then pull my old chain off . Or do u line up 12 oclock crank and cam pull chain then turn crank by itself to 3oclock turn
When do U pull the old chain before or after I turn the crank to 3 oclock?
I have sohc engine I want to know if i leave the old chain on then turn crank cause a youtube video show the crank turn without chain?
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 08-15-2016, 02:51 AM   #2
spacetrace33
spacetrace33 is on a distinguished road
spacetrace33's Avatar
Default Re: timing chain do pull chain after I turn crank 3 oclock
Three o clock , means all the pistons are in a safe place from the valves.
Oh sohc
Same rules should apply.
I know on the dohc engines, there's a hole each cam sprocket, that lines up to hole in head, where you can insert drill bit. I bet the sohc has same type of set up. But I'm getting ahead of myself here.
I'd go with 3. Just to be extra safe.
00 SL1 Daily Driver Frankenstein
98 SL2 race car-not street legal by any means
01 SC2 race car-not street legal by any means
00 SL2 aka boom boom pow
Add to spacetrace33's Reputation
Rate the quality of this post and help spacetrace33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spacetrace33 is offline   Reply With Quote
Old 08-15-2016, 09:51 AM   #3
--Turn crank to 3:00 position
--Remove chain guides and tensioner
--Remove chain
--Remove center sprocket bolt by holding cam with open end wrench on flats provided
As long as crank is at 3:00 you may freely rotate the cam.
If you PM me your email I will sent you a link to the procedure.
Timing chain when to and when not to move crank ? Packard S-Series Tech 8 02-04-2016 03:06 PM
timing chain how many degrees can i turn cam clockwise ? Packard S-Series Tech 0 02-03-2016 10:39 AM
Timing Chain? Chain loose, engine cranks, no start DJboozeAlot S-Series Tech 18 10-21-2012 02:23 PM
Spark arc's from Crank pulley to Timing Chain cover ayeayemate S-Series Mods 1 05-07-2011 01:35 AM
Timing chain crank sprocket Abe95SC2 Miscellaneous Tech 5 06-16-2002 07:18 AM
