Old 04-17-2013, 10:57 AM   #1
jchu210
jchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the rough
jchu210's Avatar
Default transmission mount
when i shift the gears, from the inside of the car i can feel my saturn buck forward, slightly. from the outside my friend says he hears a sharp CLANG type of noise.
somehow i really think that it is normal, the saturn's been like that since i got it.
other than that, the car vibrates at stops, with my foot on the brake and the gear on D. (tensioner already replaced) is the lower trans mount the culprit, something else or do you think its normal?
Add to jchu210's Reputation
Rate the quality of this post and help jchu210 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jchu210 is offline   Reply With Quote
Old 04-17-2013, 12:25 PM   #2
Highmile
Highmile's Avatar
Default Re: transmission mount
Check all your motor mounts as well as the torque struts or dog bones as they are sometimes called.
Also check the bushings between the sway bar and the lower control arms.
Hope this helps
Highmile
'95 SL1 513k and counting
Add to Highmile's Reputation
Transmission Mount? Speedrc99 S-Series Mods 5 01-05-2013 02:42 PM
transmission mount sensei420 S-Series Tech 2 05-01-2012 07:26 AM
Transmission Mount Booncha57 S-Series Tech 1 03-12-2009 11:21 PM
transmission mount ef9 vtec S-Series Tech 1 01-06-2007 05:22 PM
New Transmission Mount in. MartySzy S-Series Tech 5 07-19-2003 12:49 PM
