Old 11-21-2010, 04:25 PM   #1
DJboozeAlot
DJboozeAlot is on a distinguished road
DJboozeAlot's Avatar
Default I'm installing heated seats, which is best 12v ignition source?
I'm installing heated seats (a universal set i bought on ebay) in my 96 sc2. The instructions say this:
"find a 12v source that is capable of handling a 10-amp continuous source
that will only work when the ignition/accessory is on to prevent the seats from draining your battery when you leave the vehicle if you forget and leave them on. The seats consume about 70 watts per seat, which would drain the battery considerably without the engine running."
What would you tap into for this?
Awesome Backpacking Videos - https://www.youtube.com/user/MetalBackpacker
Detroit Ghetto Documentary - https://www.youtube.com/watch?v=nfxmshUEvbg
Add to DJboozeAlot's Reputation
Rate the quality of this post and help DJboozeAlot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DJboozeAlot is offline   Reply With Quote
Old 11-21-2010, 04:31 PM   #2
Default Re: I'm installing heated seats, which is best 12v ignition source?
A new direct fused line from the battery going through a 30amp relay activated by another key-on only source of 12v. That way the power they use comes from the battery but only when the key is on.
Old 11-21-2010, 04:33 PM   #3
quantumech
quantumech is on a distinguished road
How about the fuel pump? Isn't that 12 V and only operating while the engine is running (aside for the 5 seconds after key on and before starting, that is)?
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
Old 11-21-2010, 04:34 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
This. Installed a heated seat in my wife's car, and bought a relay to "do it right". Power comes straight from the battery, with the relay turning the power off with the radio circuit.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 11-21-2010, 04:42 PM   #5
+1^^^battery only. If you tap in anywhere else you will become the proud owner of electrical gremlins and might even let the magic smoke out.
Old 11-22-2010, 01:20 AM   #6
Where did the mfr. come up with 10A? If the seats draw 70W each, and you turn them both on at the same time, that's 140W, which, at 12VDC, is closer to 12A. Betcha it would blow a 10A fuse if you turned both on at precisely the same time.
Add to madpogue's Reputation
Old 11-22-2010, 07:43 AM   #7
spencerforhire
spencerforhire will become famous soon enough
spencerforhire's Avatar
2001 SC1
I agree that a relay is probably a good idea; if you were only using one heater and you insisted on wiring it direct you could get away with tapping into either the brown or orange 14g. wire right at the ignition switch.
01 SW2-#1 son's
01 SC2-#2 son's
00 SW2-wife's
00 SL2-daughter's
99 SW2-mine
00 SL1-spare
98 SC1-parts
+ 25 scrapped
Visit www.spencerforhire.ca to see what I do other than fix Saturns
Add to spencerforhire's Reputation
Rate the quality of this post and help spencerforhire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerforhire is offline   Reply With Quote
Old 11-22-2010, 03:42 PM   #8
wei_
wei_ is on a distinguished road
wei_'s Avatar
Doing this to my SL2 as well. On my Jeep, all electrical mods are wired to my Cirkit Boss and I'm likely to install one in the Saturn as well. Makes installing aftermarket gear much easier.
Add to wei_'s Reputation
Rate the quality of this post and help wei_ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wei_ is offline   Reply With Quote
Old 11-22-2010, 07:22 PM   #9
mfedenko
mfedenko has a spectacular aura aboutmfedenko has a spectacular aura about
mfedenko's Avatar
I gotta ask, heated seats in FLA?
Add to mfedenko's Reputation
Rate the quality of this post and help mfedenko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mfedenko is offline   Reply With Quote
Installing heated leather seats TREKKY Relay Tech 2 11-12-2009 01:59 PM
heated seats in 04 vue DMVue Vue General 3 12-31-2007 01:01 AM
Heated Seats mjdub S-Series Mods 11 11-26-2007 04:09 AM
Heated Seats TimS1965 S-Series Tech 5 10-15-2006 09:05 PM
Heated Seats Son93SL2 General Saturn Discussion 0 03-27-2001 12:28 PM
