Old 09-08-2010, 11:05 AM   #1
wdfsilverbullet
wdfsilverbullet is on a distinguished road
2002 L-Series 3.0L Wagon
Default New radiator drain plug L series
If you break or dmamge the red plastic radiator drain plug on your L sreies car/station wagon, you CANNOT get one from Saturn or GM without buying a complete new radiator. There is no salavage yard where I live in West Texas that has any Saturns. Anyone know where I can find one?
hanks for your hepl.
Add to wdfsilverbullet's Reputation
Rate the quality of this post and help wdfsilverbullet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wdfsilverbullet is offline   Reply With Quote
Old 09-08-2010, 12:19 PM   #2
Default Re: New radiator drain plug L series
Ok, last ditch attempt and to make it permanent as you can always pull the lower radiator hose off for draining; drain the radiator completely and ensure the petcock is removed to wipe it and the drain fitting dry to allow silicone sealant or epoxy. Choose whatever you like as you use the petcock to help seal the fitting permanently. Use something like Liquid Steel, a two-part epoxy (requires at least 12hrs to cure) to seal it permanently or those 5-minute epoxies if you don't want to wait. There's always a way to seal the petcock off if you use some imagination.
Old 09-08-2010, 01:23 PM   #3
beensmoked
beensmoked will become famous soon enough
2001 L-Series 3.0L Sedan
2002 L-Series 2.2L Sedan
dont do what frdyer says just yet. I just put a new radiator in my car and I still have the old one with the plug laying around. Give me 24 hours and i'll have an answer for you
norwichdelta06@aol.com
Add to beensmoked's Reputation
Rate the quality of this post and help beensmoked reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beensmoked is offline   Reply With Quote
Radiator Drain Plug Stuck? ownedinthedome S-Series Tech 0 06-21-2010 12:48 AM
Stuck radiator drain plug ifried85 S-Series Tech 9 04-18-2009 01:50 PM
Radiator drain plug wishihadacamaro S-Series Tech 6 11-16-2008 12:27 AM
How to open radiator drain plug - '02 SC2 jstin S-Series General 2 03-03-2008 10:33 PM
radiator drain plug leak wojtek_f S-Series Tech 0 08-11-2007 05:33 PM
