Old 07-30-2010, 10:19 PM   #1
dtuuri
dtuuri is on a distinguished road
1991 SC
Default Rear transmission mount: 1991 SC
I thought I had a rattle in the catalytic converter. The muffler shop showed me it was 'transferred noise' from the rear tranny mount. I could see the the rubber insert moving back and forth quite a bit as they revved the engine. I spent the whole day trying to locate a new part, but it's been discontinued because they only made them for one year. No after-market supplier could be found. The thing is right next to the exhaust pipe--no wonder it dried up and shrank. One from a junk yard would probably be as bad. Here's a pic:
So, does anybody know a way to fix this? Maybe some other rubber insert that fits in the race? How about squirting some 3M Window-weld urethane around the ate up rubber cushion? Other ideas?
dtuuri
Add to dtuuri's Reputation
Rate the quality of this post and help dtuuri reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dtuuri is offline   Reply With Quote
Old 07-31-2010, 08:40 PM   #2
dtuuri
1991 SC
Default Re: Rear transmission mount: 1991 SC
After looking a little closer, the rattle was coming from the exhaust coupler at the end of the down pipes. A couple turns of the nut to tighten the spring on one side was all it took to stop it. BUT that slop in the tranny mount has me concerned. Has anybody tried to use urethane in any of their mounts to tighten them up economically? If not, why not? What could it hurt?
dtuuri
Old 07-31-2010, 11:05 PM   #3
quantumech
quantumech is on a distinguished road
check rockauto.com, they usually have these types of things.
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
1991 Engine/Transmission Mount Replacement jlevino How-To Library 2 06-22-2012 09:33 AM
1991 Saturn SC auto transmission problem slydog S-Series Tech 7 07-21-2008 10:29 AM
1991 SC Engine Mount Question 2NDSOUT S-Series Tech 3 04-09-2008 10:43 PM
1991-1995 Rear glass between5and7 S-Series General 0 02-05-2006 04:29 PM
1991 SL1 Motor Mount/Shock Absorber? coolgreany S-Series Tech 8 01-30-2003 02:29 AM
