Old 09-03-2009, 08:23 PM   #1
aaajessy
aaajessy has a spectacular aura aboutaaajessy has a spectacular aura about
2002 L-Series 2.2L Sedan
Default l200 fuel pump
How much should it cost to replace a L200 fuel pump? Why is it so expensive?
Add to aaajessy's Reputation
Rate the quality of this post and help aaajessy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aaajessy is offline   Reply With Quote
Old 09-03-2009, 09:48 PM   #2
Phillyrican
Phillyrican is on a distinguished road
Default Re: l200 fuel pump
That is a pain. Well the pump alone cost around $326.00 yea that much i know i just put mine in my car and the labor well i did it myself with my buddy. Tell you the truth its not easy so mechanics are going to charge you alot. One really good tip if your going to do it yourself be certain that the gas tank is empty i learned the hard way. Anyways yea its a pretty expensive job do it yourself will be alot cheaper.
Add to Phillyrican's Reputation
Rate the quality of this post and help Phillyrican reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phillyrican is offline   Reply With Quote
Old 09-04-2009, 09:24 PM   #3
Cincy Saturn
Cincy Saturn is on a distinguished road
Cincy Saturn's Avatar
Wrench Re: l200 fuel pump
I had mine done recently, like a month ago at an indy shop. The GM Pump & new filter were in the 350 range. ANd then it was 3 hours of labour. They explained you had to remove the exhaust to remove the tank... and this was a two man hold the pipe and one guy unbolt. They did not think you could do it on your drive way. You will need the car up pretty good to work underneath. Nor problem if you have a lift in a shop...
The dipstick for the 710 fluid says "ADD"...Where do you buy 710 fluid ?
Add to Cincy Saturn's Reputation
Rate the quality of this post and help Cincy Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cincy Saturn is offline   Reply With Quote
Old 09-09-2009, 08:06 AM   #4
aaajessy
So $700 is a good price?
Old 09-09-2009, 09:24 PM   #5
Cincy Saturn
Thumbs Up Re: l200 fuel pump
I would say so.
Just realize that half your labour charge is to cover all of the taxes associated with having a service bay with a technician to do the work.
Old 09-10-2009, 01:22 PM   #6
crystal scan
crystal scan is on a distinguished road
2003 ION-2 Sedan
:eeks: thats alot of money hopefully mine will go out under my 2 year warrenty
Add to crystal scan's Reputation
Rate the quality of this post and help crystal scan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crystal scan is offline   Reply With Quote
Old 08-22-2010, 04:09 PM   #7
2002sat
2002sat is on a distinguished road
My gas tank is leaking near the top of the tank only when the engine is running so I'm expecting to find a bad fuel pump assy. I'm a good mechanic but now I'm thinking twice after reading how difficult a driveway job would be. I'm also trying to find a thread on how to remove the gas tank. Any help would be appreciated. Thanks
Add to 2002sat's Reputation
Rate the quality of this post and help 2002sat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2002sat is offline   Reply With Quote
Fuel Pump Change on L200 Cincy Saturn L-Series General 3 08-06-2009 07:39 PM
Help! Changed fuel pump, Now my fuel gauge is stuck on full! jimbo1490 S-Series General 5 06-14-2009 05:59 PM
2001 L200 fuel pump saluki L-Series Tech 5 02-07-2009 08:43 PM
bad fuel pump or fuel pressure regulator? blue92 S-Series Tech 5 06-30-2008 10:45 PM
2003 L200 Fuel Pump Nightmare sanchezla3 L-Series General 0 05-05-2006 03:20 AM
