Old 11-07-2008, 04:44 PM   #1
bmwboyee
bmwboyee is on a distinguished road
Default Replacing Brakes, 14mm bolt broke off
I know this sounds really dump, but what direction am I supposed to turn my wrench to remove the 14mm bolts? I twisted mine off and now have to get an ez out to remove the bolt. When looking at the wheel I was twisting left. Should I have been going the other way?
please help.
bmwboyee is offline   Reply With Quote
Old 11-07-2008, 06:01 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Replacing Brakes, 14mm bolt broke off
you were going the right way, and yes, it sounds really dump, whatever that means.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 11-07-2008, 06:06 PM   #3
bmwboyee
I assume the bolt just ceased, but i also wanted to make sure before i did the other side. I am going to soak them in WD40 this time.
Thanks
Old 11-07-2008, 06:11 PM   #4
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Thanks
Why? Are they wet? WD-40 is NOT a penetrating oil, it is a Water Displacer Formula 40. The retainers on your brakes shouldn't anywhere near rusted enough to need a penetrating oil, but for future reference, use PB B'Laster on stuck fasteners, not WD-40. Sounds like it was cross threaded to me, not rusted.
Certified Saturn Technician
Old 11-07-2008, 06:15 PM   #5
bmwboyee
cross threaded? is that going to give me problems when trying to back it out with the EZ out? and is that my best plan of attack?
Thanks for the help!
Old 11-08-2008, 10:32 AM   #6
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
"dump" Righty tighty lefty loosy
SaturnSdn is offline   Reply With Quote
Old 11-09-2008, 09:35 AM   #7
NRJIZED
NRJIZED is on a distinguished road
NRJIZED's Avatar
2006 ION Red Line
2007 Outlook XR
Just because it's a water displacement doesn't mean it's not a penetrating oil. If you look it up it does serve as a penetrating oil.
NRJIZED is offline   Reply With Quote
Old 11-09-2008, 09:59 AM   #8
Squareback
Squareback's Avatar
2005 ION-2 Sedan
And where'd you get that crap, off of their website?? Just because it says it's a penetrating oil doesn't mean it's an effective one. When was the last time you walked into a professional auto repair facility and saw a can of WD-40 anywhere? WD-40's main purpose is to displace water, thus the name. Pick up a can of PB B'Laster, you'll never go back.
Old 11-09-2008, 11:37 AM   #9
2006 ion2
2007 ION-2 Sedan
WD 40 can serve to eliminate rust, it's what I use on my tools, It can also be used as a lube, but a good penetrating it is not.
2007 Saturn Ion 2
Old 11-18-2008, 05:47 AM   #10
NRJIZED
NRJIZED's Avatar
2006 ION Red Line
2007 Outlook XR
Active duty Air Force for 16 years. Use WD-40 on rocket pods to penetrate the carbon build up on the firing contacts. Not my choice to use it. Our Technical Orders (T.O.'s) specifically call for that formula for lubrication and cleaning. In order to clean, the carbon has to be penetrated.
Wasn't necessary to come off so condescending.
Old 11-18-2008, 05:49 AM   #11
NRJIZED
NRJIZED's Avatar
2006 ION Red Line
2007 Outlook XR
Also forgot to mention to the OP. Righty tighty, lefty loosee unless the bolt is backwards, like on the calipers. So it would be the opposite. I think you overtorqued the head of the bolt right off the shank. You did write "when looking at the wheel" so the bolt is reversed from that position.
Old 11-18-2008, 07:35 AM   #12
2006 ion2
2007 ION-2 Sedan
WD 40 is great for cleaning but it's still not a penetrating lube. It's like a blackberry, it does everything a sort of well, but only one thing really well, displace water.
2007 Saturn Ion 2
Broke a strut mount bolt SL2Many S-Series Tech 2 11-07-2009 08:29 PM
Cam bolt broke..Doh.. Dutch01 S-Series Tech 3 08-26-2009 09:17 PM
96SL2, broke a valve cover bolt, how to remove the bolt? HomeBase S-Series Tech 6 04-20-2008 12:35 PM
Lugnut bolt broke! xround3x S-Series Tech 10 04-13-2007 09:19 AM
Broke stud removing lug bolt??? BarnOwl S-Series Tech 3 12-12-2005 09:56 AM
