#1 |
![]() Join Date: May 2007
Hey guys, OK, so I'm a total n00b to everything, so with that said, here goes. I own a 1998 SL2 and I want to install a custom sound system consisting of 2 subs, an aftermarket head unit, and an amp. I've looked all over the internet and I can't find any guides on how to DIY the wiring. Can you guys point me in the right direction or give me some advice? Thanks.
#2 | |
2002 SC1
![]() Quote:
For your after market deck..youll need to buy the deck..i would get one capable of DVD and SVCD play back..with video screen.. if its in your budget..when you purchase your deck..to wire it youll need to purchase the proper wiring harness adapter for your new deck/car and place you buy the deck will be able to help you with this. To wire you subs...you need to run a positive from your battery to the amp with a inline fuse..i would suggest a 4 guage amp install kit..this will include your fuse..power wire and ground and amp turn on wire( this wire needs to be attached to the back of your deck..along with the rca's for sub channel which are on the back of the deck also and will lead to your amp) While installing have the ground wire off the battery to avoid shock or damage.. connect positive battery wire with fuse to possitive on the amp..ground from the amp to a ground on the car chassis. attach wires + - right and left on amp + - on subwoofer re attach main battery hope this helps if needed i can scan ebay pick you out a good set up you also need to tune your amp ..with subs..it would need to be turned to Low pass filtering..and around 80 hz on the dial. |
#3 |
12volt.com Crutchfield.com
It really is easy to do, go to the local car audio place, tell them you need an amp wiring kit, it will have pretty much everything you need to get started. Make sure it comes with power wire, ground wire, remote wire, RCAs, various connectors. Speaker wire is a plus, otherwise buy it separately. The sites above have all the info you need to do a full "pimp my ride" style stereo set up.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it... DCS |
#4 |
Zombie and quiksc2,
Thanks for your help! Yeah I already have 2 subs. They are Crossfire BMF 1528, 15" @ 2 ohms. They are 375 watts RMS and 750 watts max each. The amp I am looking to buy is a monoblock 750 watts RMS into 2 ohms. Just to clarify, should I buy a bigger battery for my car and a 1 farad capacitor? Also, can you guys point me in the direction of any good DVD decks like Zombie had mentioned, preferably something that won't break the bank. Also, do you guys know of any good decks with Bluetooth technology? Thanks again. |
#5 | |
2002 SC1
![]() Quote:
For Decks..i prefer JVC myself...but everyone has a preference. Mine is the KD-Avx2 that i have in the saturn...but pricey Good luck..i want to see the finish product..and a SPL meter on it..that truck i posted in my saturn topic..hit 148+ DB... i havent metered the saturn yet..but seeing it lift the wiper of the windshield for 4 secs and wooble it..id say around the same.. |
#6 | ||
Thanks zombie for the advice! But I still have a few questions.
#7 |
2002 SC1
Yea Build the box yourself..3.15 cubic feet per sub? i would assume?
Go to a local sound shop..see if they have a SPL meter to test your system. |
#8 | |
![]() Quote:
#9 |
Hey guys, thanks so much (again) for all your advice. Just to let you know I have a video up if you wanna see the sub in action:
http://youtube.com/watch?v=RrlTVUdQQeg I underestimated the size of the boxes and realized I could only fit 1 sub instead of two. But it worked out nicely. I think if I had two 15" subs in an SL2 it would be too much. Anyways, thanks again and enjoy the video! |
#10 |
I work at Radio Shack and we have both a digital and an analog SPL meter. I've been meaning to borrow one and see what I'm at. I don't know what my subs or amp are rated at RMS.
#11 |
Would definately recommend at least a 1 farad cap.
I am using a phoenix gold 1 farad cap, but I have 2 Amps running through it, I plan on getting another. Right now I have 4 JL Audio 10"s in my 92 SL1, Clarion deck, Infinity speakers all around, an Infinity amp and a Bazooka amp. 2 Amps RMS is 850 and 800, So i'm around 1500+ watts.. Needless to say it pounds.. look at sound dampeners though! all that fiberglass and vinyl rattles like hell.. I used spray on rubberized undercoating on my trunk, door panels and even inside my sub boxes.. helped alot but I need more. I'll put some pics up later. |
#12 |
I checked, my amp is 150w RMS per channel, my subs I'm putting in are 700w RMS each. Haha. Time for a new amp.
#13 |
![]() Join Date: Dec 2006
2007 ION Red Line
Hello/
You may consider upgrading your Power/Ground/and Alternator cables too/ ![]() This way if you ever want to upgrade to more Amplifiers/etc.you won't need to go through the Big/3 again. I'm using the Factory Alt.(I think it's 95/Amps) w/no problems,and a DieHard Gold battery.I *may* add a 2nd battery someday for Key-Off listening.But would have to upgrade the Alt. My amps consists of Kicker old school amps/ ![]() I have a ZR/600,in Stereo Mode going to a CDT/ES620 Comp.Set in the front.The amp is giving them approx. 2x150 watts.These amps were underated.Plus I have a 2/Farad Tsunami Cap for the 2/amps. It sounds great,too/ ![]() Those amps require 4/gauge cable for Power and Ground.They are very power hungry.Be patient and take your time.If you rush to get it done...you may be going back to repair or whatever,and have to remove the pannels/etc. again to find the Issue/ ![]() So it's food for thought on the cable install,and wish you the *Best with your car and system.One more thing.I,as others,suggest dampening the car also.I removed the outer door skins and dampened them,plus the inner door skins,plus the rear deck/spare tire well and surroundings/trunk lid/etc. Kind Regards/ Raymond |
Bookmarks |
New sound system and much more | Nightwalker | Astra General | 72 | 04-06-2011 03:34 PM |
Sound system help | nothingtolose31 | S-Series Mods | 36 | 06-05-2007 05:43 PM |
New sound system (adding a amp and sub to a factory system) | QuadKewl | Ion General | 9 | 10-29-2004 04:03 AM |
Sound system? | TNCMAXQ | L-Series General | 7 | 04-04-2003 12:35 PM |
96' SL2 Sound system STORY and new system ideaR | jace3971 | S-Series General | 3 | 08-06-2002 07:44 PM |
