Old 03-29-2015, 07:25 PM   #41
510man
510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold
Default Re: Quad High Beam mod w/DRL & Fog Lights
Last edited by 510man; 03-29-2015 at 07:27 PM.. Reason: Redundant post. Added in error. No way to delete.
Add to 510man's Reputation
Rate the quality of this post and help 510man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
510man is offline   Reply With Quote
Old 05-21-2015, 10:53 PM   #42
510man
The relay coil will cause an arc across the switch contacts if there is no arc suppression diode installed. There are no diodes across the coils in that mod and it will and has burned up switches.
In the single relay mod with DRLs disabled, where is the diode installed? In the steering column?
Old 05-21-2015, 11:44 PM   #43
Put it across the relay coil.
Old 06-25-2015, 06:56 PM   #44
510man
So, the diode is between pins 85 & 86. My electricity knowledge is reasonable but my electronics knowledge is novice. A diode only allows electricity to flow
one way, as I recall.
I'll have to look to see which pin is ground and which is hot. I'm assuming I'm installing the diode to allow flow from ground to hot and not the other way. So, I'm blocking hot to ground on the coil, correct? What diode rating is required?
Old 06-26-2015, 12:02 AM   #45
robb_sc2
robb_sc2 is on a distinguished road
1999 SC2
Diode must be rated for the maximum voltage it will ever see. Add some for a safety margin. Example, 12V circuit is normally more like 12.6V, even up to almost 15V if in the charging circuit. I would put a diode rated minimum 20V. In this case it is for suppressing a collapsing field arc, I think, in which case you probably want several hundred volts ratings.
Gold 1999 SC2 ~385k Kms
Add to robb_sc2's Reputation
Rate the quality of this post and help robb_sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robb_sc2 is offline   Reply With Quote
Old 12-04-2019, 12:37 AM   #46
me.theuser
2002 SL1
2001 SL2
Dragging this one back from the dead
I did this mod on my 3rd gen with a single relay by using a diode
Apparently when the lights are off the grounded side of the headlights goes positive and the parking light positive goes to ground
File Type: jpg Saturn_Quad_Hi-Beam_Mod-single_relay.jpg (170.6 KB, 26 views)
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-04-2019, 01:24 PM   #47
98_Gold_Uranus
98_Gold_Uranus's Avatar
Would this still work on a second gen (1998) SL2 if I've disable the DRL with the "bending a prong over on the relay" method?
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-04-2019, 03:47 PM   #48
me.theuser
2002 SL1
2001 SL2
Sure would just make sure the diode is the right way before you permanently affix it
Old 12-04-2019, 04:04 PM   #49
me.theuser
2002 SL1
2001 SL2
test ahead of time by checking that the brown wire of your side marker light shows + (positive) when the parking lights are on and - (negative) or nothing when they are off
Pretty sure I did exactly the same to my 96 but thats been a lifetime ago
I just did this yesterday on my 2002 and I went in on the drivers side
corner had it done in under an hour
Do not use those wire destroying taps or t-taps
either strip the wire and wrap your new wires on to the exposed
conductors solder them and seal them very well
or cut the wires and use good butt connectors with heatshrink built-in
the wires seem kinda tight so probably the harder way to go
Either way you don't want water getting in and corroding the wires
Last make sure you stagger the joints so the harness still fits in the loom after taping it up
Old 12-05-2019, 08:35 PM   #50
98_Gold_Uranus
Oh I despise those T-taps... Not only do they destroy the wire, but they make a very sketchy connection at that... I'm a firm believer in soldering and heat shrink
I may have to give this a try. I need dig into the front and look into why my fog lights have stopped working anyhow..
How to convert DRL from low-beam to high-beam junior1983 Vue Mods 20 02-22-2013 10:27 AM
HIGH beam and fog lights danger d Astra General 4 04-20-2010 06:12 PM
What to do high beam lights? SL2-Guy S-Series Tech 4 09-01-2007 11:17 AM
daytime runing lights and right high beam out Idouoooo S-Series General 7 01-19-2007 12:56 PM
Fog lights & high-beam headlights Doc_Floyd Vue General 9 04-15-2006 10:55 PM
