Prev Previous Post   Next Post Next
Old 11-02-2019, 06:30 PM   #1
SuperKONR
SuperKONR is on a distinguished road
Default SL1 Automatic Issues
The transmission in my 02 SL1 is sometimes wanting to randomly jump into a really low gear even though I'm barely touching the throttle. It seems to only happen when it's fully warm, I don't have problems when the temp gauge is at 1/4 or below. If the heater is on it never gets past that point so I can drive it around forever with no issues. Another thing that happens when it warms up to that point is at idle in gear, the engine will slowly surge between 5-700 rpm, not sure if it's related if it is an electrical issue.
The car was wrecked in the front and whoever put it back together left half the bolts loose or missing, so I previously reconnected a ground strap to the computer that's next to the battery. Apparently that wasn't the whole issue. I've replaced the coolant temp sender.
Should I look at the TPS? Not sure how to check it if it's only malfunctioning intermittently while hot. Anything else I should be looking at? It's had an IAT sensor code for awhile, I thought it was only throwing the code because it was unplugged at one point but could that sensor be causing issues?
Add to SuperKONR's Reputation
Rate the quality of this post and help SuperKONR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SuperKONR is offline   Reply With Quote
SL1 automatic transmission issues SuperKONR S-Series Tech 3 10-14-2019 12:09 PM
My son's '98 SL1 automatic is having acceleration issues. mamagrizz S-Series General 6 08-19-2013 11:07 PM
Automatic transmission issues jaekl S-Series Tech 5 06-12-2008 01:45 PM
95 SL2 automatic transmission issues mercuris S-Series Tech 3 03-28-2007 01:07 PM
92 SL2 Automatic Transaxle issues zardoz S-Series Tech 11 12-02-2005 12:19 AM
