Old 06-07-2008, 06:54 PM   #1
billwill
billwill is on a distinguished road
billwill's Avatar
2007 AURA XR
Default "Service Traction" - "Service ESC" comes up
My '07 XR just passed 13,000 miles. As I was driving in the 102 degree heat here in North Carolina earlier today, I heard a chime and the DIC displayed "Service Traction" and the "TC" symbol came up with the slash through it. Then it dinged again and displayed "Service ESC" and the ABS warning came up. I pushed the Traction Control button but nothing happened.
Anybody know what's going on? It appears that I need service, but on what? I bought the extended warranty when I bought the car new in July '07. Is this going to cost me something? Is it part of a recall? Has any of you had this on your Aura? TIA.
Add to billwill's Reputation
Rate the quality of this post and help billwill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
billwill is offline   Reply With Quote
Old 06-07-2008, 07:46 PM   #2
mrwerner22
mrwerner22 is on a distinguished road
mrwerner22's Avatar
2007 AURA XR
2002 VUE 3.0L
Default Re: "Service Traction" - "Service ESC" comes up
it happened to me once but instead of being hot it was really cold. but once i turned it off and turned it back on they went away and everything was good... so im not sure.
2007 Aura XR... NICE
Add to mrwerner22's Reputation
Rate the quality of this post and help mrwerner22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrwerner22 is offline   Reply With Quote
Old 06-07-2008, 08:08 PM   #3
dishdude
dishdude is on a distinguished road
2008 AURA XE
Sounds like a speed sensor went bad, there is one at each of the wheels. If one sends an odd signal to the computer, it shuts the whole system down and you get the service esc message. It will be covered under warranty, just take it in and have them look at it!
2008 Saturn Aura XE I-4 Techno Gray
Add to dishdude's Reputation
Rate the quality of this post and help dishdude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dishdude is offline   Reply With Quote
Old 06-09-2008, 10:24 AM   #4
Tom-ADC
Tom-ADC is on a distinguished road
2005 ION-3 Sedan
Thumbs Down Re: "Service Traction" - "Service ESC" comes up
Just went through a "Reduced engine power & Service Traction" problem happened twice car would barely run, they replaced the Electronic throttle positioner if I remember correctly.
Guess what it happened again this morning was coming back from a coffee with the guys things and barely had enough power to make it home, so its off to the dealer again, last repair lasted about 180 miles
2007 Aura XE 3.5
1969 Dodge Dart GT
1971 Dodge D-100 shortbed
Add to Tom-ADC's Reputation
Rate the quality of this post and help Tom-ADC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom-ADC is offline   Reply With Quote
Old 06-13-2008, 07:01 AM   #5
billwill
billwill's Avatar
2007 AURA XR
Saturn service found that a wire going to the right front speed sensor had come loose. They replaced it as well as the wheel bearing since the wire had been rubbing against the bearing and they didn't want to take a chance the bearing might be damaged in some way. All under warranty... everything's back to normal. Can't beat my Saturn dealer.
Old 06-13-2008, 10:52 PM   #6
Tom-ADC
2005 ION-3 Sedan
Post Re: "Service Traction" - "Service ESC" comes up
got mine back yesterday, dealer says they replaced the engine computer but they didn't have the paper work ready so they just gave us the keys and said they would mail the paper work to us.
Soon as it gets here I'll know what was actually replaced. BTW car has 3001 miles on it since November 2007.
2007 Aura XE 3.5
1969 Dodge Dart GT
Old 06-14-2008, 08:25 AM   #7
billwill
billwill's Avatar
2007 AURA XR
My Saturn Service Manager said whenever a wheel speed sensor "goes bad," it causes the ABS (Anti-Lock Braking System) warning light to come on as well as the Traction Control warning and Electronic Stability Control warning... whew.
Does anyone know if, when the ABS warning light comes on, the ABS is totally disabled and you have only standard braking? I don't drive fast enough in conditions (hopefully) to need ABS but would like to know; I forgot to ask the Saturn guy. TIA.
Old 06-14-2008, 10:15 AM   #8
circlotron
circlotron is on a distinguished road
2007 AURA XR
I just had a MAP sensor replaced for this fault. The "Service Traction/Service ESC" would occur and then clear on the next ignition cycle. The engine control computer was replaced last year for the same fault. It wasn't happening often so the dealer put a data recorder in the car and I drove it for a week to capture more fault data.
I hope they really got it this time.
Add to circlotron's Reputation
Rate the quality of this post and help circlotron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
circlotron is offline   Reply With Quote
Old 06-14-2008, 11:11 AM   #9
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
abs light on. abs off. cant risk running it with a problem as it could be dangerous. my aura had a brake fluid leak which also trigerred traction control and esc light because of low brake fluid
Add to onefunkar's Reputation
Old 06-14-2008, 12:10 PM   #10
It would be wise to read your owner's manual for assurance and if not answered to call Saturn for a more definitive answer. Any time the ABS/TC/ESC warning light turns on while driving always leaves you with standard brakes. Your concern will be when the RED brake warning light turns on anytime after releasing the parking brake; the RED brake warning light turning on now means something has occurred to lower the brake fluid in the brake master cylinder. There may not be enough brake fluid for safe stopping and this should be examined immediately as driving may become dangerous.
ABS/TC/ESC are all enhancements to the basic braking system so their failure won't endanger the driver. The brakes will always work but the RED brake warning light is cause for immediate concern in the general scheme of things.
VCX NANO
Old 06-14-2008, 01:08 PM   #11
VWCarcrazy
VWCarcrazy is on a distinguished road
2008 AURA XE
My kid drives my 2001 Bonneville that has a lot of bells and whistles (my wife hates that car). This winter he called me from college a few hours away to say that the TC and Anti-lock brake warnings had come on. I told him to ignore them, and called our local dealer (no GM dealer in the small college town knows anything). My local dealer noted that we had just gone through an ice-storm and very slushy roads, and said it was a very common problem with these systems. He suggested getting the car inside to warm up, or take the car through a carwash and pay extra to get the underbody wash. My kid did this and the problem went away and did not return. Seems these systems are very sensitive to extreme heat (over 100 deg F), extreme cold (below -10 deg F), freezing slush/ice buildup around wheels/brakes, internal moisture (condensation, not rain), etc. that can effect wheel speed and balance or the wheel sensors themselves. The GMC/Pontiac dealer said that the sensors are quite expensive to replace, and are many times replaced unneccesarily by a worried owner or a profit-seeking dealer doing parts swapping instead of real diagnosis. And that it is not a big issue to drive a short time with either warning light on. If the light stays on for a long time (ie: many days or a week or so), take it to the dealer. If it is under warranty and you have time to burn, take it in sooner than later. Best luck.
Add to VWCarcrazy's Reputation
Rate the quality of this post and help VWCarcrazy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VWCarcrazy is offline   Reply With Quote
Old 12-10-2013, 05:37 PM   #12
Kiminohio
Kiminohio is on a distinguished road
I was wondering if there is a chance that something could have happened to my sensors for my traction control when I had all 4 tires changed? it just started acting up after I had new tires put on.
Add to Kiminohio's Reputation
Rate the quality of this post and help Kiminohio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kiminohio is offline   Reply With Quote
Old 12-10-2013, 06:14 PM   #13
Is this a Lamborghini, Bentley, Mack truck? Some info would help.
VCX NANO
Old 12-06-2018, 11:01 AM   #14
Project84
Project84 will become famous soon enough
Project84's Avatar
2009 AURA XR
Bumping this old thread because my car has been doing this for over a year and although I've taken the main fuse box apart under the hood and cleaned every single pin/connector, cleaned battery terminal, and cleaned about 5 or 6 grounds I could find, the problem remains the same.
Service ESC and Service Traction flash on the dash as well as ESC OFF and Traction OFF.
I'm trying to sell the car at this point because I've read so many horror stories of this eventually stranding you or the steering failing while driving the car and causing near accidents.
Only problem is I'm selling the car with full disclosure and no one wants to buy a friggin' death trap!
I'm aware these issues have been discussed for some 10+ years. Has no one actually figured out the root cause of the issue?!
John
'09 Saturn Aura XR 2.4L
Previous - '01 SL1 daily driver and '96 SL2 auto 40+mpg hypermiler.
Add to Project84's Reputation
Rate the quality of this post and help Project84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Project84 is offline   Reply With Quote
Old 12-06-2018, 08:32 PM   #15
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Check the connections to the VICM on the passenger side of the dash, dropping the glovebox will reveal it and it will be on the right side of the glovebox. My ESC and TC message would come on and so would the anti-theft/key light would come on as well...I unhooked the VICM and replugged it back in and it has not come back on since.
However, you may still have a faulty speed sensor, or a wheel bearing causing the issue.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is offline   Reply With Quote
Old 12-16-2018, 08:40 PM   #16
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
I just had this happen during the test ride right after I replaced front calipers and rotors/pads. And coincidentally, I have a wheel bearing going bad.
Very sensitive, these sensors!
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
2000 L 3.0L 85K miles speedometer and "service engine soon" codes v-bob L-Series Tech 5 02-11-2009 07:24 PM
Another "SERVICE ESC" question Budd Aura General 0 09-24-2008 07:40 PM
OBDII code "Service Engine Soon" 03 VUE 2.2 / 5sp skijay Vue Tech 2 10-30-2006 05:14 PM
Can "Service for Engine" light be caused by improper auto repairs?? Aurora88 S-Series Tech 3 06-08-2005 01:13 PM
This week's VUE glitch (or "My service dept is nice but dim") wmacblue Vue General 4 05-24-2002 03:40 PM
