Old 02-03-2014, 12:35 PM   #61
Default Re: New or Returning S-Series owners' checklist Version 3.0
Originally Posted by nytek View Post
All the utube links don't work, am I doing something wrong?
It's possible that a video has been updated, which means the link is no longer any good.
YouTube probably has a search; or you can use google to search for a particular video. For example, try this search (copy and paste):
richpin06a saturn site:youtube.com
This will find the terms "richpin06a" and "saturn" but limit the search to the site youtube.com
Or substitute a phrase, like
troubleshoot saturn starter -ion site:youtube.com
(the minus sign before ion means the search will not include hits with the word "ion" - different saturn model; this search will find videos by others as well as richpin)
Old 02-21-2014, 10:04 AM   #62
YouTube does have a search, use richpin06a saturn followed by what you are looking for.
Old 02-21-2014, 09:01 PM   #63
eb121209
eb121209 has a spectacular aura abouteb121209 has a spectacular aura about
eb121209's Avatar
Here is the direct link to Richpin's YouTube page... http://www.youtube.com/user/richpin06a
Add to eb121209's Reputation
Rate the quality of this post and help eb121209 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eb121209 is offline   Reply With Quote
Old 03-12-2014, 11:35 PM   #64
eb121209
eb121209's Avatar
Old 03-30-2014, 02:19 AM   #65
ShinyNewSC2
ShinyNewSC2 is on a distinguished road
If your temperature gauge STILL looks this after an ECTS replacement:
Then you need a new thermostat. In addition, double check the connector to make sure it is NOT corroded, and the terminations are SOLDERED AND HEAT SHRINK WRAPPED.
The following pics are the damaged ECTS/TTS:
This is a new ECTS/TTS, side by side with the old one for comparison:
Saturn 96 model year and newer temperature gauge reading vs. actual temperature as read from the ECTS.
GAUGE Reading..........ECTS Temperature..........Event
.....1/4.................................150 F
.....3/8.................................192 F...........T-stat cracks open
.....3/8+................................195 F
.....1/2...............................212 F
.....9/16................................221 F............Fan ON
.....7/16................................210 F............Fan OFF coast to 205 F
(FWIW, some people, specifically on Gen-3 Saturns, have reported that the fan will click on at ~212 degrees F (half line).)[/QUOTE]
So if this is what my Saturn gauge looks like all the time, does that mean I'm running too cold and it's an issue that I should resolve as soon as I can? What should it really be running at temp-wise?
Add to ShinyNewSC2's Reputation
Rate the quality of this post and help ShinyNewSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShinyNewSC2 is offline   Reply With Quote
Old 03-30-2014, 07:00 PM   #66
eb121209
eb121209's Avatar
Not true all the time. I had my thermostat replaced and I replaced my ECTS with a brass tipped one. ECTS connector is not corroded. Also the ECTS connector was replaced, soldered and heat shrink wrapped and my gauge reads at a 1/4 but actual coolant temp was taken using a ELM327 OBD2 scanner linked to my iPhone, and the temp is right where it's supposed to be.
Old 03-31-2014, 05:30 PM   #67
Chano1215
Chano1215 has a spectacular aura aboutChano1215 has a spectacular aura about
2000 SW2
Ginger root in the radiator for minor head gasket leaks? I thought it was pepper.
Add to Chano1215's Reputation
Rate the quality of this post and help Chano1215 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chano1215 is offline   Reply With Quote
Old 04-04-2014, 05:08 PM   #68
Signmaster
That's what happens when a chart is posted based on the testing of a single car and the assumption that the single car is the norm. In reality simply variance of the ECTS could move the gauge, as well as changes in operating temp. So at best the chart is a general guide, despite the fear mongering that the gauge MUST read a very specific point when fully warmed.
Old 04-04-2014, 07:53 PM   #69
eb121209
eb121209's Avatar
I use my phone to monitor gauges and it reads exactly where it's supposed to.
Old 04-05-2014, 09:15 AM   #70
Signmaster
And "exactly" is at what temperature?
Both thermostat operation and ECTS resistance ranges are given in ranges, not exacts. So based on the information provided by GM, there is no exact. But that's my point. There are a lot of people chasing some exact, whether it be operating temp or gauge position. It's been proven many times over that they vary car to car regardless, and the closest that can be given is really just a range.
Reported temps through a scanner are nothing other than the exact of what the ECTS reports, but without an exact range given for the ECTS this really does not confirm that the indicated temp is the actual operating temp at all.
And as for thermostats, the factory thermostats and many aftermarket thermostats are all within the specified range, but if within the range none is more to spec than the other really, unless you want to shoot for the middle of the spec at the proper spot. And doing that is just a guess really.
Old 04-05-2014, 09:25 AM   #71
Fine grind pepper will work also if you want to use it but you need to know how much.
Old 06-02-2014, 10:30 AM   #72
catric69
catric69 is on a distinguished road
catric69's Avatar
Originally Posted by adventureoflink View Post
ATTENTION:
Due to U-tube not wanting to accept video URLs as anymore, until I decide to update this (which most likely should be very soon) in the interim you can either:
1. remove the www of the URL in your address bar then visit the video like normal (easiest)
That is all.
This is my first post on the forum, but I followed these instructions and the utube links work like a charm. Also, Thanks to all the members that have contributed to and put this information into one super thread. It is greatly appreciated!
'14 XV Crosstrek CVT
'13 Outback Limited 3.6R
Add to catric69's Reputation
Rate the quality of this post and help catric69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
catric69 is offline   Reply With Quote
Old 09-15-2014, 03:09 PM   #73
SCCentex
SCCentex is on a distinguished road
2002 SC1
[QUOTE=adventureoflink;1850469]***continued from post #1***
20. Throttle Body. I'm sure you've noticed a sticking accelerator (NOT like the Toyotas mind you), slightly less gas mileage, harder to push in the accelerator, idle being funky especially when stopping at stop lights/signs, right? If so, these are the classic signs of needing to give your throttle body and IAC (Idle Air Control) Valve a good scrubdown. Oh yeah, if you start the car, the idle pegs at ~2,000 RPM, and you shut the car down and it goes away, it's time to replace the TPS (Throttle Position Sensor). Don't worry, it's also right on the Throttle Body as well.
Throttle Body/IAC Valve Cleaning:
This really helped. lol My intake is as bad as the TB was, is there an easy way to clean it?
Add to SCCentex's Reputation
Rate the quality of this post and help SCCentex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SCCentex is offline   Reply With Quote
Old 01-19-2015, 06:57 PM   #74
Jmims16
Jmims16 is on a distinguished road
Dizzy Re: New or Returning S-Series owners' checklist Version 3.0
Hi, I'm in dire need of assistance my mom gave me a 2001 saturn sc1 1.9 SOHC after she had told me it only needs a new engine because she blew a head and who knows what else was wrong with it. Anyways I ordered and engine from an online source the engine had only 50,000 miles on it for 650$ I thought what a steal free car and cheap engine. I went on to buy new parts for the car to cover the warranty on the engine. Engine showed I swapped it out myself, fired it up and it ran for about five minutes before I noticed it was leaking radiator fluid I shut the car off tightened all the leaks fired it back up and it ran for another ten minutes or so then it died. I started it back up and it idled rough then when I went to give it gas it idled lower decelerated and died I got it to star a few times but same outcome eventually it wouldn't start again. I immediately started troubleshooting and buying parts: fuel filter, fuel pump, ignition coils, ignition module (but I took that back) to the point where I was going broke and wife was starving then decided I need professional assistance since I'm no mechanic anyways I took it to a local shop they ran a diagnostic and got no codes but when they tested my fuel rail with an ohmmeter it was putting out too much they decided that that's regulated by the PCM and I need a new one. So I got my car back and sat on the idea for a few day since it was nothing definite given to me as of what the problem is. So I started messing around with it and I noticed that the security light would not go off but thought nothing of it (because I'm oblivious) and went on to go buy a new PCM swapped it out and for some reason really paid attention to the not going away SECURITY light so I looked up some things and came up with my car was in theft mode I did the bypass relearn and it fired right up for 30 seconds and then died as I tried to give it gas like it did when I first got the engine in. So once again decided I need a pro or two so I took it in to the local Gm dealer and they charged me 240$ to tell me I need a new crankshaft position sensor and connector but you need that before we know anything else. I gave Em their 240$ and bought the parts myself took the car home and did it myself still cranks but won't start I have spent over 1400$ on hanging parts on this car and haven't driven it a mile yet and around 2,050$ total on it please pleas please help I need clarity and a running Saturn sc1
Add to Jmims16's Reputation
Rate the quality of this post and help Jmims16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jmims16 is offline   Reply With Quote
Old 02-08-2015, 01:24 PM   #75
Virago6
Virago6 is on a distinguished road
Lil Red..02, SL2, 124K miles.. wife's daily driver from house to school where she teaches 0.8 miles one way then, now it's a 24 mile drive to new school.
SEL on Lil Red came on....thanks to the advice, AZ for code, yep..upstream O2 sensor. I did the sensor gig and I SUCK at electrical stuff..splicing just ain't in my fortune....while I was under there, decided to change plugs to NGK coppers, change oil...pulled PCM-b fuse to reset computer...also did the ECTS just to make sure. Yep. it was all grody and worn...
My better half took it to the school and came back exclaiming that it seemed to run smoother and the SEL light went out and stayed out.
Again, folks. Thanks
Add to Virago6's Reputation
Rate the quality of this post and help Virago6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Virago6 is offline   Reply With Quote
Old 04-09-2015, 02:30 AM   #76
MLX10
MLX10 is on a distinguished road
wow what a list. I guess I should get started. I just bought a 95 sc2 auto. definitely have the reverse slam issue. so I'll get on that. I love that there are YouTube videos to doing alot of the work bc im going to need them for sure. I'm no mechanic but I'm handy so I should get on this. my temperature gauge is just a hair off the middle on the cold side... do you think this is due to an aftermarket thermostat?
Add to MLX10's Reputation
Rate the quality of this post and help MLX10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MLX10 is offline   Reply With Quote
Old 04-09-2015, 02:31 AM   #77
MLX10
I'll post a pic when I can get my phone to upload pictures on here.... sorry newbie
Old 04-09-2015, 06:01 AM   #78
Pitcher
Pitcher's Avatar
Welcome! Nope, that's about where the temp gauge should be. You have a good thermostat.
Have fun with the other things & let us know how it goes!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Old 04-09-2015, 07:59 AM   #79
MLX10
Happy Re: New or Returning S-Series owners' checklist Version 3.0
great thanks. I think I'm going to start a new thread to map my journey. maybe it can serve as a helper to someone who isn't a mechanic and wants their saturn to last forever.
I really think I found a gem with this car. I really like the look and the pop up lights. 95 with only 85k and seems to be mechanically sound. nobody seems to understand why I like it so much Haha. glad this forum exists. this will be my second car as a commuter. I'm sure you'll be seeing my name alot on here since I love doing things myself and taking care of my things. I'm an avid member on my other forums so I'll make sure I give this one my attention and keep my sc2 well documented
Old 05-19-2015, 04:35 PM   #80
MrAnon
MrAnon is on a distinguished road
Alright, that's just not fair! Here I was thinking I was the low-mileage 95 SC2 champ at 86k and you come along with only 85k. Cheater! Meanie! Evildoer!
Add to MrAnon's Reputation
Rate the quality of this post and help MrAnon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrAnon is offline   Reply With Quote
New or returning owner's S-series checklist Version 2.0 adventureoflink S-Series General 35 09-13-2013 12:17 PM
New or returning owner's S-series checklist. adventureoflink S-Series General 36 02-21-2012 11:56 PM
.PDF version of owners manual?? Twenty4 Aura General 4 02-09-2007 03:34 PM
s series owners that now own ions saturn_guy Ion General 24 11-16-2005 05:00 AM
Since I didn't get any response from the S-Series owners Glacius Mods and Performance 2 07-29-2003 06:48 PM
