Old 11-12-2008, 07:32 AM   #1
aheroawakend
aheroawakend is on a distinguished road
Default Slight tapping when I first start up
I think my valves may just need re adjusting after she warms up in summer or winter/fall shes fine it stops. It started maybe 6 months ago. I did a oil change myself since my dealership charges like 60 for every thing and local auto shop had a deal on oil and filter i just picked up some stuff to flush out the system but its still there.
So is it something easly done if i need a slight valve adjustment or just take it to dealer and ask them what they can do?
Add to aheroawakend's Reputation
Rate the quality of this post and help aheroawakend reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aheroawakend is offline   Reply With Quote
Old 11-12-2008, 08:26 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Slight tapping when I first start up
the way this timing/valve system is, if it slipped you'd be in serious trouble. If it'll help you sleep better at night, you can check that all the timing marks are lined up, but it'll take a little work. Mine sounds a little odd compared to some higher end 4 cylinders at idle also, but once it warms up to 80F, I'm off without another noise. I wouldn't worry about it, these engines can sound a little clicky when idling, but so are most, it's actually the MPFI system tht clicks on my car, and every ford fucus the rental car companies have made me drive have done the same thing. open the hood and listen, if you have a stethoscope, locate the sound.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Rate the quality of this post and help 2006 ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-12-2008, 09:35 AM   #3
OnDaGround
OnDaGround has a spectacular aura aboutOnDaGround has a spectacular aura about
OnDaGround's Avatar
1993 SC2
Well, assuming you knew what you were doing when you did an oil change, sounds like a case of the lifters. Get a can of BG MOA, its a additive that you put in the oil. It helps to reduce lifter noise. Try that you can do it before the next oil change. Or if you still have your warranty take it to saturn. Other than MOA (oh do this when the engine is hot). Another old school trick that I learned from the old timers is put a quart of ATF in there with the oil, run it for an hour 1/2 or drive it for a hundred miles, then flush it out and do an oil change. Should be as good as new with no ill effects.
Lifter noise is a common thing in modern chevys, for example my malibu. And you have a motor built basically all by GM even though the Ion came before the Cobalt.
Saturnless...
Add to OnDaGround's Reputation
Rate the quality of this post and help OnDaGround reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OnDaGround is offline   Reply With Quote
Old 11-12-2008, 03:11 PM   #4
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
ecotec's click alot its very possible that its the fuel injectors clicking at idle..
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 11-12-2008, 03:18 PM   #5
aheroawakend
Thanks guys Ill take a look at it on my next free day.
Old 11-13-2008, 06:49 AM   #6
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
Attention Re: Slight tapping when I first start up
This is required reading before adding anything to your engine but oil.
http://www.saturnfans.com/forums/showthread.php?t=38696
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline   Reply With Quote
Old 11-13-2008, 02:59 PM   #7
OnDaGround
OnDaGround's Avatar
1993 SC2
start it up when its cold and put your ear to the Valve cover, if its ticking then its lifters or you need oil lol... if not then check the injectors like the other guy said.
Saturnless...
Old 11-18-2008, 06:11 AM   #8
NRJIZED
NRJIZED is on a distinguished road
NRJIZED's Avatar
2006 ION Red Line
2007 Outlook XR
You don't need to listen to the valve cover to know if you need oil. Pull the dipstick. It can tell you. There is no need to adjust lifters on thes cars as they have hydraulic lifters. No adjustment necessary. More than likely you're either hearing noisy valvetrain (which is normal on these cars) or noisy injectors (also normal). You can always add an injector cleaner to your fuel-ups or pay for an injector cleaning service if this really bothers you. But this sounds like normal operation.
Add to NRJIZED's Reputation
Rate the quality of this post and help NRJIZED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NRJIZED is offline   Reply With Quote
Old 11-18-2008, 09:20 AM   #9
OnDaGround
OnDaGround's Avatar
1993 SC2
I was saying that if you can hear the tapping from the VC then you have lifter noise.... or you do not pay attention to your car and you should check your oil because you have none (I was making a funnay). durr.. As far as whether or not you have adjustable lifters; makes no difference as to whether they make noise, or do not make noise. And at that, I made no refference to adjusting the lifters.
Saturnless...
Old 11-19-2008, 02:17 AM   #10
aheroawakend
I know I dont need oil just did a oil change with a friend. Also did the gunk clean out liquid that gets rid of build up.
Old 11-19-2008, 08:04 AM   #11
2006 ion2
2007 ION-2 Sedan
they got you good, if you use a good oil, you never have to remove "gunk" (sludge), other things like additives and cleaners actually void the warranty on these engines as they often take away more than just sludge, if you're really worried about it, use castrol or mobil1, or even better, use synthetic, or drop your pan and scrape it out, but never do THAT again.
2007 Saturn Ion 2
Old 11-19-2008, 10:29 AM   #12
OnDaGround
OnDaGround's Avatar
1993 SC2
+1 most additives hurt more than help. Especially the cleaners.
Saturnless...
tapping ects aperich2 S-Series Tech 6 10-02-2008 02:54 PM
Engine Tapping zoso007 S-Series Tech 4 05-14-2006 11:07 PM
Tapping into the Ant. CRAZYENGEL Ion General 0 07-20-2005 12:26 PM
do any of u get a slight miss during a cold start up (L81) Satty V6 L-Series General 6 12-13-2003 05:11 PM
engine tapping Hrdfrz S-Series Tech 5 03-13-2002 06:47 PM
