Old 03-02-2008, 01:27 PM   #1
kx250ryder
kx250ryder will become famous soon enough
Default Crankshaft Relearn Procedure
I got a CPS by mail from saturnparts.net along with the gaskets for the valve cover (DOHC).
I was going to do this all today, but then noticed that most say you need a Tech2 scanner to achieve the crankshaft relearn procedure.
I did find this post which suggests otherwise:
http://www.saturnfans.com/forums/sho...59&postcount=6
Does this procedure apply to the 1998 SL2 I am working on? I noticed both of the poster's cars were pre-OBDII. I would really like to avoid a dealership at all costs if possible.
It will be a couple weeks before I can try this because the car has a SES code P0420 for the converter that I still need to replace.
Add to kx250ryder's Reputation
Rate the quality of this post and help kx250ryder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kx250ryder is offline   Reply With Quote
Old 03-02-2008, 01:42 PM   #2
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Default Re: Crankshaft Relearn Procedure
i do not believe you need anything other than a 10mm socket. You can replace the sensor and either let the car relearn over a period of driving cycles or force a relean my disconnecting the batter/remove PCM B fuse.
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
Add to rc1488's Reputation
Rate the quality of this post and help rc1488 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rc1488 is offline   Reply With Quote
Old 03-02-2008, 02:28 PM   #3
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
It is my understanding that the relearn thing is specific to 96 models(well problems) with learning .
It has been suggested ,there was a glitch in the programming(first year)obd 2
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 03-02-2008, 04:01 PM   #4
ssicarman
ssicarman's Avatar
Ideally the crank relearn should be done when the crank sensor is replaced.
It needs to be done when the crankshaft or the engine is replaced. This is so that the PCM knows for sure where the tooth on the crank that locates the #4 cylinder top dead center is.
Add to ssicarman's Reputation
Old 03-02-2008, 07:10 PM   #5
kx250ryder
I agree that the relearn probably needs to take place. My question is of the now three methods of re-learn (from costliest in time and dollars to least):
1. Saturn dealer uses Tech2 to relearn
2. I perform the specific drive cycle mentioned by Low Saturn
3. I install the sensor and just drive it per rc1488
Will option 3 work? Or must I use option 2 or worse the dreaded "no-grease-in-the-rear-pay-dealer-labor-cost" option 1?
Old 03-02-2008, 11:51 PM   #6
Old95SL2
Old95SL2 is on a distinguished road
1997 SL1
Just change it and drive, worked fine on my 99.
Add to Old95SL2's Reputation
Rate the quality of this post and help Old95SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old95SL2 is offline   Reply With Quote
Old 03-02-2008, 11:58 PM   #7
TwinRevver
TwinRevver is on a distinguished road
I swapped an 98 motor with about 60k miles in 95 SL2 and swapped all necessary sensors over. So i need to do crank relearn??? How does low saturn do it?? (option #2).....
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 03-03-2008, 12:37 AM   #8
ssicarman
ssicarman's Avatar
I have yet to see a problem caused by not doing a crank relearn after replacing the CPS. There is something to be said for modern production line tolerances. That would include engines and crankshafts. Now if you have an unexplained miss or similar then a relearn may be the fix if the sensor, crank or engine have been replaced.
So far as I am aware the ONLY way to do a relearn is with the Tech 2 scan tool.
Old 03-03-2008, 12:53 AM   #9
rc1488
rc1488's Avatar
when in put the '97 engine in the '99 car it worked fine with no relearn
Old 03-03-2008, 10:59 AM   #10
TwinRevver
would this cause 20 mpg?? yes the ects and conn. is fine(brass)...
Old 03-03-2008, 11:42 AM   #11
BarnOwl
BarnOwl's Avatar
2000 SW2
In my experience, and I had a '96 that had to get a crankshaft relearn, if you aren't having another problem, you don't need a crankshaft relearn. In my case, I was getting a P0300 code that I couldn't get to go away. I spent a lot of time and money chasing that code. OTOH, I swapped an engine from a '97 SC2 into a '97 SW2 and didn't need to get the relearn done. It's running great!!!
Add to BarnOwl's Reputation
Old 03-03-2008, 09:17 PM   #12
ssicarman
ssicarman's Avatar
I would tend to think that it will not. Have you replaced the thermostat?
Old 03-04-2008, 03:03 PM   #13
kx250ryder
Change and drive seems to have worked so far. But I have heard that a re-learn wouldn't happen with a SES light set. So until I swap out the cat for the P0420 code and clear it out, I don't know if things will stay ok or not.
CPS relearn procedure harley2003 S-Series Tech 12 03-16-2009 10:33 PM
computer relearn procedure (how to) iacv claude thibault S-Series Tech 4 01-24-2009 10:04 AM
crankshaft variance learn procedure cvppjp S-Series Tech 2 06-08-2008 02:39 PM
Crankshaft Learn Procedure tijeraspete S-Series Tech 7 11-25-2006 06:37 PM
Crankshaft Relearn on 2000 SL1 Frank3 S-Series Tech 22 11-19-2005 01:59 AM
