Old 01-01-2007, 12:29 PM   #1
Laga
Laga is on a distinguished road
Default Changing Serpentine Belt
I will be changing the belt on my 04 2.2 in the next few weeks. It has 50k miles on it and this is just part of my personal maintenance schedule. It looks like it is going to be a real PITA because of the tight spaces. Any suggestions on making it easier? Does the inner fender liner come off? Thanks for any help.
Add to Laga's Reputation
Rate the quality of this post and help Laga reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Laga is offline   Reply With Quote
Old 01-01-2007, 01:39 PM   #2
delivery man
delivery man is on a distinguished road
delivery man's Avatar
2004 ION-2 Quad Coupe
Default Re: Changing Serpentine Belt
I had to buy a serpentine belt tool because there isn't enough room to get socket in there. Good luck with it.
Add to delivery man's Reputation
Rate the quality of this post and help delivery man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
delivery man is offline   Reply With Quote
Old 01-02-2007, 01:22 AM   #3
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Use a jack under the engine, remove the air box and the engine mount. Really easy once you do that. Takes maybe a half hour in a driveway. Hope it helps!
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-02-2007, 02:10 AM   #4
I normally go at it from under the car. Remove what ever plastic shileds you need to to get to the tensioner. A 3/8 drive swing arm fits into the tensioner to release the belt tension.
Add to ssicarman's Reputation
Old 01-05-2007, 02:50 PM   #5
teebird
teebird is on a distinguished road
I know what you are saying. There is NO clearance between the fender liner and the tensioner for a 3/8" ratchet. I tried. You would have to buy a serpentine belt tool. I may just have it changed since I've got enough "Used Once" tools in my garage.
Add to teebird's Reputation
Rate the quality of this post and help teebird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
teebird is offline   Reply With Quote
Old 01-05-2007, 06:34 PM   #6
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Ok since i've done this like 3 times here ya go.
Get 3/8" breaker bar from napa, jack up car, take off plastic covering crap, put breaker bar into tensioner, pull, take belt off idle pulley, remove belt.
done
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 01-11-2007, 02:54 PM   #7
Laga
I pulled off the airbox and plastic fender liner. Rented the long tensioner tool from Autozone but was unable to use it because it was too long from both the top and bottom. After taking the top motor mount off I found that if you pry on the engine carefully with a piece of wood the engine moves just enough to get your 3/8in drive ratchet with a short piece of pipe on it. Done Thanks for the replies
Changing the serpentine belt on the Ecotec David 93 SL2m How-To Library 19 07-05-2019 07:04 AM
About serpentine belt and belt tensioner xybaby S-Series Tech 5 01-04-2010 12:42 PM
Changing the v6 serpentine belt binkers L-Series Tech 17 12-05-2009 08:48 AM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 09:23 AM
Changing / Replacing Serpentine Belt cmswq3 S-Series Tech 6 01-30-2003 12:29 PM
