Old 06-28-2004, 12:13 PM   #1
"Sadurn"
"Sadurn" is on a distinguished road
Default What is a DRL relay?
On my engine compartment fuse panel, there is a relay-looking thing that the chart on the cover calls "DRL". Just curious, what is it?
I looked through all the schematics and the closest I could find was a door lock relay (DLR) BUT, I don't have power door locks?
The car is a 95 SC1, 5-speed. Also, I noticed an ABS relay and ABS fuse. Does this mean I have anti-lock brakes? The previous owner said it didn't.
Just getting to know my new beautiful toy. Thanks for any education here!
Add to "Sadurn"'s Reputation
Rate the quality of this post and help "Sadurn" reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
"Sadurn" is offline
Old 06-28-2004, 12:36 PM   #2
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Default
DRL relay is for your Daytime Running Lights.
My '94 SL1 has an ABS relay and fuse, but I definetly do not have ABS. I would assume that the previous owner is correct (Especially living in Canada with the ice and snow and stuff...)
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline
Old 06-28-2004, 12:50 PM   #3
"Sadurn"
Default
Thanks Kevin !
"Sadurn" is offline
Old 07-06-2004, 06:04 AM   #4
Kentai
Kentai is on a distinguished road
Default
Incidentally, if you're wanting to disable your DRL's, I've got your simple solution.
Add to Kentai's Reputation
Rate the quality of this post and help Kentai reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kentai is offline
Old 07-06-2004, 10:36 AM   #5
"Sadurn"
Default
Thanks for the offer but they don't really bother me. Is there any advantage to this besides longer bulb life? Cheers.
"Sadurn" is offline
Old 07-06-2004, 05:22 PM   #6
Kentai
Default
Not annoying other drivers during the day with your DRLs is about it...
Kentai is offline
Old 07-07-2004, 01:23 AM   #7
sierrap615
sierrap615's Avatar
Default
with ABS, you should have rear disk brakes too, not drums
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 07-07-2004, 12:40 PM   #8
"Sadurn"
Default
Naw, 99% of cars on the road here have them. It's a "Canadian" thing, or maybe just an Ontario thing? I dunno but soon bicycles will require them, knowing us!
Cheers...
"Sadurn" is offline
Old 07-08-2004, 06:50 AM   #9
Kentai
Default
Ah, that's right, you Canadian types are silly like that.
Kentai is offline
Old 07-08-2004, 03:00 PM   #10
Kevin94SL
Kevin94SL's Avatar
2006 ION-3 Sedan
Default
All Saturn's that were sold in Canada have running lights....
Kevin
Old 07-08-2004, 03:07 PM   #11
psybapunk
psybapunk is on a distinguished road
Default
whats the trick for disabling the DRL?
Add to psybapunk's Reputation
Rate the quality of this post and help psybapunk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
psybapunk is offline
Old 07-08-2004, 05:00 PM   #12
r_o__
r_o__ is on a distinguished road
r_o__'s Avatar
Default
pull the drl relay, the only thing is if you do you'll only have one high beam that will come on
Add to r_o__'s Reputation
Rate the quality of this post and help r_o__ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
r_o__ is offline
Old 07-09-2004, 12:43 AM   #13
sierrap615
sierrap615's Avatar
Default
or pull the fuse, i think that will save your headlight
Old 07-11-2004, 09:23 PM   #14
JPDucketts
JPDucketts is on a distinguished road
Default
DRL's are required in Canada.
Add to JPDucketts's Reputation
Rate the quality of this post and help JPDucketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JPDucketts is offline
Old 07-12-2004, 12:29 AM   #15
sierrap615
sierrap615's Avatar
Default
but is that required on all cars at all times or only required to have them when sold new?
Old 07-12-2004, 07:24 PM   #16
lpkortuem
lpkortuem is on a distinguished road
Default
psybapunk: It is illegal to disable daytime running lights. Gm tec. assiatance people will give out info on disabling DRL only if the car is "Authorised" to have them disabled.
Add to lpkortuem's Reputation
Rate the quality of this post and help lpkortuem reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lpkortuem is offline
Old 07-12-2004, 08:12 PM   #17
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default
just do a search...you jump two slots and you're good...
If you get pulled over, you get a fix-it ticket and you're back where you started...
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline
Old 07-12-2004, 08:28 PM   #18
bigbird
bigbird is on a distinguished road
bigbird's Avatar
Default
DRL's have been required by law in Canada since 1989. Very few people disable them.
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 07-12-2004, 11:31 PM   #19
JPDucketts
Default
if it was equipped with DRL's when new you have to have them.
Old 07-13-2004, 12:25 AM   #20
swzine
swzine is on a distinguished road
swzine's Avatar
Default
yeah but you tell me how many cops have a list of cars with DRL's memorized. Especially if you bought it used - "It didn't have DRL's when I bought it! I had no clue".
I'd love to hear from a person that actually got a ticket for disabling DRLs! Until every car has them I couldn't see anyone getting in trouble. Now during inspection they might notice!
If cops have time to give tickets for DRL "violations" they don't have enough to do.
"God Bless America, and no Place Else!"
-Head of State movie
Add to swzine's Reputation
Rate the quality of this post and help swzine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swzine is offline
removing the drl relay chris54 Vue Tech 7 12-29-2013 07:16 PM
DRL relay, what one is it? autoxvw Vue Tech 3 07-02-2007 10:54 PM
DRL Relay Pins dshivers Vue Tech 3 07-02-2007 06:49 PM
DRL Relay charlies Vue General 5 03-24-2007 08:59 PM
Need DRL relay for 96 SL2 Chisel86 S-Series Tech 3 01-19-2007 11:23 AM
