#1 |
![]() ![]() ![]() Join Date: Feb 2017
I recently bought a used 96 SC2 that needs some help. It will be my son’s first car.
It has good tires wheels new water pump, belts, thermostat. It had 85K miles. I was told it needs heat gasket but we are going to rebuild the motor. It was leaking some water into the trunk and we found where it was leaking. Today we put sealant inside and outside the leaking area. We will test it tomorrow. The previous owner took black spray paint and blacked out all the turn signal lens. I spent some time with lacquer thinner and Novus 2 polish. One less thing to buy. The picture shows the other one that still needs done. The one I did looked just like it when I started. |
#2 |
![]() ![]() ![]() ![]() Join Date: Apr 2016
God speed and good luck Comrade. We look forward to your build thread.
#3 |
We have the leaks fixed in the trunk we tested it good with a garden hose. The tail lights are done and I am happy with how they turned out. Two less things to buy.
#4 |
I took my headlight motor out it is a pain.
This great post helped on here helped me out. http://www.saturnfans.com/forums/sho...d.php?t=143946 Yes my gear is bad I ordered a new one off ebay. This plastic one lasted 21 years I hope the new one last at least half long we will be fine. |
#5 |
The motor and gears are shared with the C5 Vette and 90's Firebird so there's proper upgrades available to that plastic crap gear.
http://www.ebay.com/itm/Corvette-C5-...del%3ACorvette Can probably do any headlight mod/upgrades to your SC2 that people have done to those cars as well. If I could find another '93-'96 SC2 5spd I'd be in hog heaven ![]() |
#6 |
Thanks for the info.
I ordered the $8 shipped version. http://www.ebay.com/sch/i.html?_from...86696&_sacat=0 I will be trying to keep the cost down but still have everything work on this one. I almost printed one with my 3D printer but for $8 shipped it was not worth the time to make one. |
#7 | |
![]() Quote:
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#8 |
Thanks.
The long lenses on the trunk is not turning out as good so far. I think he added clear coat over this black. I have not given up on this just yet. The driver’s power window is now working I took apart the switch and cleaned up the contacts. Now I hear it clicking in the door so I need to take off the door skin and see what it going on. |
#9 | |
![]() Quote:
http://www.saturnfans.com/forums/sho...d.php?t=223010 (Occasionally I am off the forums for a while so wanted to post a link in case it turns out to be that plastic slider)
#10 |
Thanks sweet… I like it.
![]() My 3D printer may get to print something useful for this car. |
#11 |
The car will need a paint job. I have seen posted where some people have had good luck with tractor paint. I think I might give this a try with red paint.
It is Oil Base Enamel $29 gallon Catalyst Hardener $16 Majic Reducer $10 I need a junk yard dash and inside door panels. Is SC and SL the same? What years will have the same dash and door panels? 1996-1998 I have a 2002 SC2 and a SC2 1999 at a u-pull it place. Last edited by Mark_b; 02-27-2017 at 09:07 PM. |
#12 |
You have one of the odd-ball years. The cluster is near unique to a 96 and The door panel might be as well.
#13 |
My headliner has no material on it at all. The visors are completely missing.
I just ordered the 3m Yellow Super Trim Adhesive and the fabric from Jo-Ann Fabrics. As suggested from this post. http://www.saturnfans.com/forums/sho...d.php?t=180985 I looked at the photos in this post and it really changed look of the car. |
#14 |
Cluster will swap from any other '96 DOHC ('97+ has the upshift light on the wrong side). Possible '95 as well, but I'd only if it were the only option or under $20. SOHC's will fit in and function but the signal range for the speedometer and tach are calibrated to show higher speed/rev on the DOHC, it won't show actual road speed or actual engine RPM.
Dash can be from any '95 model or any other '96 coupe, it's a 3-piece thing that they turned into 1-piece for '97+ coupes and '96+ 4dr's. I'd be surprised if a true 2nd gen door panel swaps onto it but may be worth trying if cheap enough. 90% sure the doors back are 1st gen plastic's with 2nd gen handle/locks cut in. '99 will work better than '02 for swapping parts but there's still very little body parts to use from a "true" 2nd gen like '97-'99's are. '95 & '96 coupes are sorta Gen 1.5's while the 4drs were Gen 1.5's for just '95. |
#15 |
My driver’s windows regulator is bad and I need to replace it. I am not finding new ones for this car. I found lots from Gen 2 Saturn’s just not for my 96.
I can get one from a junk yard none of the self-serve yards around me have Gen 1 Saturn’s. There some on http://car-part.com but you wonder what you will end up with. Are there any good options for this part? Last edited by Mark_b; 03-05-2017 at 11:27 AM. |
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
![]() Quote:
1999 SL2 MT (287,130 km @ 10/2019) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#17 |
It is the regulator mechanism I found lots of new motors.
I am just not finding regulator mechanism for the 96. Last edited by Mark_b; 03-05-2017 at 11:51 AM. |
#18 |
I my 2 cans of 3M Super Trim Adhesive came in. I finally got the headliner fabric from Joann fabric. 3 yards 50% off $23
The local store had to have it store to store transferred for me. I went to Upull it. Bummer my son could not come you have to be 16 to enter the yard. I got a new dipstick, map light switches, visors, 95 aluminum valve cover with all the bolts, wheel cover and a timing cover. The previous owner did not take off the top middle bolt and broke the timing cover and all the bolts. It took a long time to get that timing cover off at the Junk yard. You need to take a lot of stuff to get it off. All these parts for $69 I will have to recover the visors. Last edited by Mark_b; 03-12-2017 at 11:14 AM. |
#19 | |
![]() ![]() ![]() ![]() Join Date: Aug 2016
![]() Quote:
You can scavenge used tail lamps for way cheaper than the cost of refurbishing the originals that were ruined by the P.O.
"What does a Saturn owner do, at the gas station?" "He checks the gas, and fills the oil....." |
#20 | |
![]() Quote:
The flaw is the center rivet. It bends, over time. I have found, that if you loosen the tracks and move the window up and down, it can prevent further damage. As the rivet wears out, the window tilts. Since the tracks are tight, this actually worsens the problem. So, you can get a decent used regulator. Just make sure you adjust the tracks to have a tiny amount of play. You should only have to loosen the bottom bolts, of each track, move the window up and down to see how you need to reset them. Worked like a charm on my manual regulators. Left window kinda "stutters" at the halfway point, but it stays in the track throughout the total movement distance, where before it was tilting forward and coming out of the track at the rear. www.wholesalegmpartsonline.com is for a Chevy dealer, in Kentucky. They may still have regulators in stock, or be able to order them.
Bookmarks |
2004 Saturn Ion 2 QC 2.2 manual - revs slowly, returns slowly to idle | chetterhead | Ion Tech | 14 | 09-22-2012 11:43 PM |
Bringing the old gal back to life | Hjoken | S-Series Tech | 21 | 02-24-2012 12:45 PM |
Could Magnas Unique Business Model Lure Penske into Bringing the Astra Back to Lif | wifeofcore | General Saturn Discussion | 14 | 06-18-2009 12:46 AM |
Bringing 94 SL1 back to life - been sitting for 3 1/2 years | Spazie | S-Series General | 19 | 01-02-2008 02:19 PM |
bringing a $400 SC2 back to life | geartooth94 | S-Series Tech | 9 | 01-12-2005 09:31 AM |
