Old 03-17-2013, 06:20 PM   #1
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
Default Accessory Belt change - lw2 V6 3.0 litre
Wife's 2000 wagon had to be towed home after her shift yesterday. Sounded like the accessory belt slipping bad.
Today I found the belt tensioner was completely melted, therefore no tension on the belt and no charging the vehicle.
When I went to replace the belt I found it was surrounded by a motor mount. Is there a magic way to change this belt without having to remove the mount?
Seems ridiculous to design such a thing in this fashion.
There must be an easier way to do this.
Any input is appreciated.
Thank you.
Add to burlyvue2's Reputation
Rate the quality of this post and help burlyvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burlyvue2 is offline   Reply With Quote
Old 03-17-2013, 06:54 PM   #2
Default Re: Accessory Belt change - lw2 V6 3.0 litre
No way to do it without lifting the engine up off of the engine mount. If you use the oil pan to lift the engine make sure that you spread the load across the pan, IE piece of wood. Service manual does not reccomend lifting the engine by the oil pan for risk of cracking it.
Add to ssicarman's Reputation
Old 03-17-2013, 07:02 PM   #3
burlyvue2
2004 VUE 3.5L
Thanks for the quick reply ssicarman. The service manual does not even mention this, just states remove the old belt.
If I support the engine from below it is possible to remove the engine mount and clear with the new belt or does the engine have to be removed?
Has anyone done a "how to" on the subject?
Thanks again.
Old 03-17-2013, 08:48 PM   #4
You only need to unbolt the mount from the engine to get the space so that you can slip the belt through the space.
Old 03-17-2013, 09:35 PM   #5
burlyvue2
2004 VUE 3.5L
U rock ssicarman!
I found a how to in the "how to" section. I need to study up on the search aspect of this site.
I will be doing the engine mount removal and belt replacement prolly next weekend as it needs to be done and weekends are better for car stuff.
Old 03-18-2013, 11:07 AM   #6
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Make sure you check the tensioner, Mmain reason on L's for belts meltin is the tensioner bearings failed and the tensioner locked up.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 03-18-2013, 06:29 PM   #7
burlyvue2
2004 VUE 3.5L
The tensioner was seized and melted. Seriously messed up!
Old 03-19-2013, 03:04 PM   #8
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
My tensioner was in overall nice shape but bearing was worn. Was able to buy bearing only at Advance Auto Parts for a nice savings over replacing entire tensioner assembly.
Also have a 2008 Astra XE
Add to PeteB's Reputation
Rate the quality of this post and help PeteB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PeteB is offline   Reply With Quote
Accessory Belt Tensioner Brands dragonslord S-Series General 4 02-28-2012 03:28 PM
Can't get accessory belt tensioner to move? Lurker1999 S-Series Tech 18 11-13-2011 11:36 PM
Noisy Accessory belt myolbug S-Series Tech 3 06-22-2011 01:05 PM
Belt and Accessory Questions AndreasChen S-Series Tech 2 04-09-2010 12:31 AM
Noise from accessory belt aaronsw2 S-Series Tech 2 01-09-2006 12:18 PM
