Old 01-11-2013, 09:23 PM   #1
jburgess025
jburgess025 is on a distinguished road
2001 L-Series 2.2L Sedan
2006 VUE Red Line
Default Just Question about 2001 L200 exhaust manifold
2001 L200 exhaust manifold on 2.2L engine with manual transmission ... No New Parts available ... Junkyard dont have them ...
What is solution to repair ... on part that unique to 2001 L200 .... And Part GM No Longer Makes ... I cant be only one having this issue ...
Add to jburgess025's Reputation
Rate the quality of this post and help jburgess025 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jburgess025 is offline   Reply With Quote
Old 01-11-2013, 10:19 PM   #2
pierrot
pierrot's Avatar
Default Re: Just Question about 2001 L200 exhaust manifold
Welcome to the SaturnFans Forum! It's unfortunate for you that there were far fewer L's with the manual transmission and that may make it more difficult to locate the manifold you're looking for.
Some specialty engine rebuilding shops may be able to weld the manifold if it isn't fully broken, but that's only a distant possibility. Try looking around on the link below. It has wrecking yard information from around the US, Canada, and Mexico.
http://www.car-part.com/
325,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 01-11-2013, 11:38 PM   #3
PeteB
PeteB is on a distinguished road
PeteB's Avatar
2002 L-Series 3.0L Sedan
1994 SC2
Getsaturnparts.com has them. Not cheap.
Also have a 2008 Astra XE
Add to PeteB's Reputation
Rate the quality of this post and help PeteB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PeteB is offline   Reply With Quote
Old 01-11-2013, 11:57 PM   #4
pierrot
pierrot's Avatar
I hadn't even thought of looking into the new GM parts websites. Another site to view has it priced somewhat lower:
http://catalog.gmpartsdirect.co/?i=2...n=7&type=parts
Yet another site prices them really high:
http://gm-partscenter.com/parts/2001...iagram=IC00250
Old 01-12-2013, 09:31 AM   #5
PeteB
PeteB's Avatar
1994 SC2
gmpartsdirect.com seems to have removed Saturn from its catalog.
That was the first site I checked.
Old 01-12-2013, 01:06 PM   #6
pierrot
pierrot's Avatar
The site you mentioned above is not the same as the one I recommended. The one listed above is ".com" and my recommended site is ".co." Strangely enough, they aren't the same site. http://gmpartsdirect.co/
Old 01-13-2013, 08:49 PM   #7
Frostman
Frostman will become famous soon enoughFrostman will become famous soon enough
2002 L-Series 2.2L Wagon
1993 SL1
I have had this issue. Manifold cracked and flex pipe went. Was able to weld the cracks, but went with custom down pipe.
Eventually I will be putting my pacsetter exhaust manifold on. Most that I have found have had luck, but no one has tried it on a manual before.
If you go custom, make sure you get someone that is good. I broke the first custom flex pipe because the angle that it was welded at was not the best.
Add to Frostman's Reputation
Rate the quality of this post and help Frostman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frostman is offline   Reply With Quote
Old 05-16-2014, 07:38 PM   #8
hemi4cam
hemi4cam is on a distinguished road
take the cracked manifold to an expert welder who has a stainless MIG welder setup, and it CAN be welded. I had one welded and it lasted about 3 years. Buy a spare used cracked one and weld that too. When the one cracks again, change it out and weld the other one again. They eventually crack on both sides of the weld.
Add to hemi4cam's Reputation
Rate the quality of this post and help hemi4cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hemi4cam is offline   Reply With Quote
Old 05-21-2014, 03:35 PM   #9
linearbit8
linearbit8 has a spectacular aura aboutlinearbit8 has a spectacular aura about
linearbit8's Avatar
http://www.gmpartsonline.net/parts/2...UST%20MANIFOLD
Second one down.
"Saturn Modder" on Google+
http://www.soundcloud.com/linearbit8
Add to linearbit8's Reputation
Rate the quality of this post and help linearbit8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
linearbit8 is offline   Reply With Quote
Old 05-21-2014, 11:22 PM   #10
Zsolt
Zsolt is on a distinguished road
Zsolt's Avatar
Saw this and it got me wondering, is the exhaust manifold different from manual to auto tranny's on the 2003 l200 as well?
Add to Zsolt's Reputation
Rate the quality of this post and help Zsolt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zsolt is offline   Reply With Quote
Old 05-22-2014, 09:32 PM   #11
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Yes. The exhaust pipe goes UNDER the steering rack for the MT. The AT exhaust pipe goes OVER. That, combined with the fact that the engine sits 2" farther back with the MT, means the exhaust manifold runners are much more straight down from the head than for the AT. I think one of the reasons for the different exhaust routing is to avoid the shift mechanism on the manual.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-25-2014, 03:14 AM   #12
Frostman
1993 SL1
Damn I hope not... I am hoping my pecsetter will go over the rack when ever I get the time to do it...
Old 05-26-2014, 10:52 PM   #13
born again
@Frostman- There should be room to go over the rack, but you may have to do some fancy routing and make some heat shields,etc. to keep from cooking/melting things. Have a look on yours.
2001 L100 2.2L Manual Exhaust Manifold mywifessaturn30 L-Series Tech 3 05-18-2012 10:44 PM
2001 L200 manifold nordo L-Series Tech 1 12-02-2010 09:22 PM
2001 Exhaust Manifold removal question waldo_2001 S-Series Tech 1 05-31-2008 01:11 AM
2001 L200 atx exhaust manifold cracked btrautman L-Series Tech 13 05-03-2005 03:59 PM
Exhaust smell in cab - 2001 L200 lawarr L-Series Tech 2 02-18-2005 06:46 PM
