Old 04-08-2003, 01:00 AM   #1
jasons56
jasons56 is on a distinguished road
Default Help me find reverse/valve body fix!
My 94SW2 has the well known problem with the long delay when shifting into reverse. Now it has developed a ratcheting sound that occurs sometimes when you put it in park. It sounds like some kind of pawl skipping across some gear teeth. It usually eventually engages.
I heard that Wolfman posted a fix for the reverse problem, but I just can't seem to find the post.
So what is the trick?
Thanks!
jasons56 is offline
Old 04-08-2003, 02:03 AM   #2
94sc293sl1
94sc293sl1 is on a distinguished road
94sc293sl1's Avatar
1994 SC2
Default
Welcome to the board.
Don't quote me, but I believe you put blocks behind the wheels and leave the car in reverse for about 20 minutes. Someone correct me if I'm wrong.
Craig
Saturn owner no longer as of 12/21/05, sold my SC2.
www.insidetrackmagazine.com
94sc293sl1 is offline
Old 04-08-2003, 10:28 AM   #3
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
It can *help* but will not cure the problem totally.
~D.J.~
OhioVueBoy is offline
Old 04-08-2003, 01:11 PM   #4
wolfman
wolfman's Avatar
Default
Guess I better repost it...DO NOT make up your "OWN VERSION" follow the instructions exactly.
The "works nearly everytime" cure for the reverse "slam"
1. Change the transaxle fluid and filter (use "conventional" not synthetic fluid)
2. Add your choice of automatic transmission fluid additive (transmedic, Lucas etc...personal choice, Prolong auto transmission additive)
3. Start the car firmly set the parking brake, chock the wheels and or back it up against a firm immovable object (A brick wall works well)
4. Put the car in REVERSE and LEAVE IT THERE, RUNNING, IN REVERSE, for about 20-30 mins at idle.
What this does is use the clean transaxle fluid and additive to flush out the reverse passage in the valve body by simulating driving in reverse for about 10 miles. IT WILL NOT HARM THE TRANSAXLE OR ENGINE IN ANY WAY. After completing this proceedure, (99 times out of 100) your reverse slam will vanish for at least several months and maybe forever (actually usually forever is a better description) Maintain the transaxle correctly from that point forward. If it initially does not work for long, you can REPEAT the proceedure without changing the clean fluid and sometimes net good results BUT if after 2 tries thing have not improved you are probably looking at valve body replacement. YOU MUST CHANGE THE FLUID FIRST! Doing this with "dirty" fluid still in the transaxle may actually make it WORSE. Also "normal" transmissiopn "flushes" WILL NOT cure this problem, as they don't feed enough "warm" clean fluid through the valve body for long enough.
wolfman is offline
Reverse Slam Valve Body replacement Reverse Fork MichelleG S-Series Tech 16 04-06-2009 06:48 PM
Re-occuring valve body problems even after a fix?! usairwaysjett2 S-Series Tech 11 08-03-2008 01:50 PM
Will reverse slam or new valve body fix this? chevy57 S-Series Tech 0 12-26-2007 11:18 AM
new valve body-no reverse Nowhere Man S-Series Tech 29 08-02-2006 10:28 PM
Valve Body Fix maxtrac Miscellaneous Tech 0 08-04-2002 06:13 AM
