Old 04-04-2011, 05:53 PM   #1
camzshaft
camzshaft has a spectacular aura aboutcamzshaft has a spectacular aura about
Default 2002 Sc2, what is the name of the reverse light housing located on the bumper?
I need to get a new set and I can't find them anywhere! I also don't know what they're actually called so any search I do only ever shows me results for tail lights.
camzshaft is offline   Reply With Quote
Old 04-05-2011, 02:57 PM   #2
camzshaft
Default Re: 2002 Sc2, what is the name of the reverse light housing located on the bumper?
Nobody? Not even a gentle prod in the right direction so I can find out myself?
Old 04-05-2011, 03:09 PM   #3
BV22
2002 SC1
Try "back up lamp housing".
Old 04-05-2011, 03:23 PM   #4
http://www.trademotion.com/partlocat...layCatalogid=0
if that astronomically long link doesn't work:
GetSaturnParts.com ->Input car info->Rear lamp->Backup Lamp->Backuplamp Assembly. $25.13 per side, right & left different.
Old 04-05-2011, 03:41 PM   #5
camzshaft
Thank you
Old 07-08-2016, 05:24 PM   #6
KSabo
KSabo is on a distinguished road
KSabo's Avatar
Also, thank you - I was just looking for the correct GM # for these. Much appreciated.
Black 2002 SC2 manual 1.9L DOHC - 210,000 miles (July 2017)
KSabo is offline   Reply With Quote
Reverse light fuse located where? destro5 S-Series General 3 05-25-2008 12:48 AM
Tail Light Housing Melted edisonline L-Series General 10 05-13-2008 03:37 PM
Removing Sunroof/Map Light housing zeemo13 S-Series Tech 0 05-05-2007 10:59 AM
rear reflector/ reverse light housing $? fetchitfido S-Series General 0 06-24-2006 08:56 AM
Moisture in rear singnal/reverse light housing Son93SL2 S-Series Tech 2 05-27-2000 08:28 PM
