Old 05-27-2010, 09:22 PM   #1
NewVue2009
NewVue2009 is on a distinguished road
Sad MPG for 2009 Vue XE AWD
I recently purchased a (practically brand-new) 2009 Vue XE with AWD. When I look at the MPG it's supposed to get according to the lists at the Saturn/GM site it says it should get from 16 to 23 MPG. It has a panel that displays the average fuel economy in the car and it says only an average of 15.4 MPG. I've gotten an oil change and I'm only at 6500 miles on the car. I'm only getting 15 mpg. Why is my MPG so low on this nearly new car? And what can I do to improve it? It's way worse than the van I traded in for it. (BTW - I am NOT heavy on the pedal or brake at all) Any ideas??
Add to NewVue2009's Reputation
Rate the quality of this post and help NewVue2009 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NewVue2009 is offline   Reply With Quote
Old 05-27-2010, 09:33 PM   #2
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
2004 ION-3 Quad Coupe
Default Re: MPG for 2009 Vue XE AWD
Give your Vue's engine some time to break in...you are only at 6,500 miles, that engine is barely worn in. I would imagine that as you keep racking up the miles, your mileage will begin to improve. Also, unfortunately most '08 and '09 Vue owners seem to have found that the EPA ratings on the window sticker seem to be very generous. I would likely blame this on the fact that the tests are done under more or less perfect conditions that are nearly impossible to achieve in real world driving. Also, the '08 and '09 Vue is pretty heavy by small crossover standards due to its frame design and safety features, which certainly doesn't help its fuel economy. Just try to give it some time to wear in and try to drive as conservatively as possible to try and reach those EPA numbers.
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
Old 05-27-2010, 09:57 PM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
I suspected that this engine combination worked too hard in the 2008-09 VUE's chassis. The parasitic load from the AWD system doesn't help either.
Keep your tire pressures on the high side, and use synthetic oil. Mobil 1 is a good choice.
Add to BobbyP's Reputation
Old 05-28-2010, 11:55 AM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
did you reset mpg display or is that since new?
Add to onefunkar's Reputation
2009 VUE 6 spd vs 4 spd engnenk Vue Tech 7 02-12-2010 03:32 PM
2009 vue MMarlin Vue General 10 10-27-2009 10:19 PM
2009 er vue michael_downs 2008 Vue 5 11-22-2008 09:19 AM
2009 Vue ??? jgibson146 2008 Vue 3 07-26-2008 12:30 AM
Changes for 2009 djreed Aura General 76 04-11-2008 01:56 AM
