#1 |
![]() Join Date: Jun 2006
I recently picked up a 95 SL2 on Craigslist. After an engine swap and various other items I have the car on the road and it runs nice. Only a couple of issues left.
I have been over the forums looking but perhaps I have missed it. The temp gauge in the car does not work. At start up the needle with twitch up very slightly but will not move from that point. I picked up the correct 95 temp sensor today and installed it and checked the wiring. I'm getting 6.3 volts give or take at the plug at the sensor but the gauge will not budge. I have let the car warm up and checked this but nothing. Could the gauge in the dash be bad? Thoughts and other checks would be appreciated. The rear defroster switch goes on but not off. I'm going to check the chime and fuses and relays for that but is there anything else I should check. I appreciate everyones feedback. Thanks Mike
97 SL2 95 SL2 98 GMC Yukon 94 Jeep Grand Cherokee 07 Suzuki Boulevard C90T 1500cc I'm Not Tailgating.. I'm drafting!! |
#2 |
Some models have two temp sensors, one for PCM (2 wires) and other for the gauge (one wire?). If have two, maybe you checked/replaced PCM ECTS and the problem is with the other one?
For the rear defroster, assuming it is actually defrosting the rear window but wont' turn off, there are only 3 possible problems: switch, relay, or CHIME module. It can't be the fuse or it wouldn't work at all. Relay is in the front right (passenger) footwell fusebox, new one costs like $9 or $11 at the parts store. Try swapping in an identical relay from something else you're not using at the moment, maybe power windows or fuel pump, or whatever uses the same relay down there. Don't know how to diagnose CHIME module. Mine stopped chiming around the same time the rear window defroster stopped working, which is how (with help from Saturnfans.com) I figured to replace it. Bought mine from a dealer, but you might be able to find one on eBay or in a junkyard. In case you need a switch, I happen to be selling one that might fit your car (definitely fits 1996-1999), as long as you don't have fog lamps or traction control. I'll sell it cheap! Send me a PM if you're interested. But check relay first--you don't want to be like me and buy a new defroster switch only to find your current one was fine after all. And I suspect your problem is relay or CHIME, not the switch.
'98 SL2 w/slushbox; Prothane dogbone inserts; eBay front STB; Progress springs 1.8" drop; Progress 19mm rear swaybar; KYB GR-2 struts; 3/8" rear hub spacers; rear disc brake swap. |
Bookmarks |
Aura XE 3.5 - Overheating / Temp Issues w/ Scan Gauge Photos | usa4624 | Aura General | 23 | 05-14-2009 08:30 AM |
Rear & Mirror Defroster Quit Working! | JButler1983 | L-Series Tech | 2 | 01-09-2008 08:27 PM |
97 T-stat & Temp. Gauge | Ls1Junky | S-Series Tech | 3 | 11-08-2007 06:22 PM |
New battery installed, now door chime & rear defroster won't work. | rhurle02 | S-Series Tech | 4 | 01-30-2007 03:30 PM |
New Stereo and Rear Defroster Power issues... | ninjajester | S-Series Tech | 2 | 01-26-2006 08:58 PM |
