Old 05-18-2009, 09:27 PM   #1
Partymmudasti
Partymmudasti is on a distinguished road
Partymmudasti's Avatar
Default L300 Fuel Filter
After the better half told me today that our 2005 L300 stalled after being started first thing this morning, I decided to do some probing around.
- No codes stored (pending or present), or freeze frame data.
- Just changed air filter 2 weeks ago and changed oil.
- Car has 3/4 tank of gas. We have a Shell card, and only get fuel from Shell.
- I run a bottle of Techron Concentrate (~$12) through the tank before every oil change
I decided to start with basics and change the fuel filter. It was $9.99 at Autozone, and the counter kid was more than happy to take my $10.59 and send me away.
Get home, locate fuel filter (pass. side under the car near the rear door) the screw is frozen. PB Blast it and let it soak for a few while I open a tasty frothy beer. Take screw off, needle nose to the quick connects and WOW. Some black nasty stuff is coming out! I get the fuel filter to the garage, coincidentally there is a glass sitting on the bench that I was drinking diet 7-up out of yesterday, I shook whatever fuel was left in the filter out into the cup and it was totally dark grey I cant wait to cut it open in a few days and see whats in there - pictures to follow.
Guess with 65,000 miles and 4 years on the fuel filter, it must've been overdue! Car now starts with new zest, seems to idle alittle higher now.
A friendly reminder to change your fuel filter. It was a 10 minute job and cost a whopping $9.99.
Add to Partymmudasti's Reputation
Rate the quality of this post and help Partymmudasti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Partymmudasti is offline   Reply With Quote
Old 05-18-2009, 10:57 PM   #2
spareribs
spareribs is on a distinguished road
2002 L-Series 3.0L Sedan
Default Re: L300 Fuel Filter
I am thinking of changing my fuel filter also on 2002 l300, hope the fuel filter is in the same location. Could you giveme a step by step instruction on locating the fuel filter and how to change it.
Add to spareribs's Reputation
Rate the quality of this post and help spareribs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spareribs is offline   Reply With Quote
Old 05-23-2009, 12:12 AM   #3
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
It is not much more that was described in the first post. There is a strap that holds the filter that has a screw holding it. Undo the screw. Put a shallow pan under the filter to catch the fuel that will drip out when you disconnect the lines. Use a pair of needle nose pliers with the jaws spread over the fuel line tube. Slide the jaws towards the collar on the fuel line at the end of the filter. Push the collar into the filter. Push the fuel line into the filter, then while continuing to push on the collar, pull out the tube. Repeat at the other end of the filter. Drop the filter into the pan. The lines will still be dripping. Put the new plastic collars over the tubing ends, then insert them into the new filter. Note the flow direction marked on the filter. Do up the strap. Done.
Dont even think about smoking or or have any sparks or flames around when you do this. The filter location is the same for all L-Series.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-23-2009, 02:39 PM   #4
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
Oh Lord yes....change them at least every 2 years. Every year is better, but I never remember either.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Add to Ex-GMtech's Reputation
Rate the quality of this post and help Ex-GMtech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ex-GMtech is offline   Reply With Quote
Old 05-24-2009, 10:18 AM   #5
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Thanks for the reminder, mines past due.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
2003 L300 Fuel Filter sunshine010702 L-Series Tech 5 11-11-2013 12:28 AM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 07:29 AM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 10:43 PM
How do I access fuel filter in L300? greenworks L-Series Tech 1 01-07-2005 10:14 PM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 10:14 PM
