Old 07-22-2008, 11:45 AM   #1
branch99
branch99 is on a distinguished road
Dizzy Harmonic balancer
Is it possible for the crank shaft bearings to be so worn that crank shaft has to much play in it and allows the harmonic balancer to rub up aganst the engine block? I have a 1998 sl2 and am on my third harmomic balancer in about 4 months. The just keep breaking.
Add to branch99's Reputation
Rate the quality of this post and help branch99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
branch99 is offline   Reply With Quote
Old 07-22-2008, 11:49 AM   #2
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Default Re: Harmonic balancer
It would be the crankshaft thrust bearings. But you'd normally have some issues with the flywheel/flexplate hitting the block instead of the damper. Most of the crankshaft thrust forces push the crank forward (particularly with a manual trans), which wears the rear of the thrust bearing or crankshaft. You don't often find the front part of the bearing worn, though it's not impossible.
Old 07-22-2008, 11:53 AM   #3
OnDaGround
OnDaGround's Avatar
1993 SC2
are you putting it on yourself or a backyard mechanic?
Saturnless...
Old 07-22-2008, 08:29 PM   #4
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
Uh after the first one Ida found out what the problem was.....
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
Add to xtremeranger's Reputation
Rate the quality of this post and help xtremeranger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xtremeranger is offline   Reply With Quote
Harmonic Balancer striker1584 S-Series Tech 2 05-19-2009 11:32 PM
Harmonic Balancer Clickety_Clack S-Series General 6 11-16-2008 09:48 PM
harmonic balancer branch99 S-Series Tech 4 07-21-2008 07:38 PM
Harmonic Balancer SL2_Gold S-Series Tech 10 12-18-2007 07:29 PM
Harmonic Balancer? NVMY03GT S-Series Tech 27 03-24-2007 07:09 AM
