Old 12-26-2007, 11:18 AM   #1
chevy57
chevy57 is on a distinguished road
Default Will reverse slam or new valve body fix this?
Guys,
97 SC1. My wife hit something in the road that broke one of the tranny lines. I repaired the line. Changed the filter and fluid. Since then you need to rev the motor up to get it into drive. You only need to do this one time. For example if you stop at a light and start out it acts fine. If you shift from drive to reverse and back to drive it acts normal until you shut it off. When you restart it you must rev it up again to get it in drive. I have been driving this like this for 2 years. I don't think the tranny is toast as I have been using it for 2 years. I suspect it is a pressure regulation problem. Computer is throwing p0722, P0731, P0732, P0733 and P0734 codes. Do you think the reverse slam procedure will fix this? It has no slam when you put it in reverse. The only problem I have is in drive. How about a new valve body? Will a shop replace just a valve or selenoid?
chevy57
Add to chevy57's Reputation
Rate the quality of this post and help chevy57 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chevy57 is offline   Reply With Quote
Reverse slam: cost to replace valve body & tighten nuts? DWVANDY S-Series Tech 4 09-30-2009 03:30 PM
Reverse Slam Valve Body replacement Reverse Fork MichelleG S-Series Tech 16 04-06-2009 06:48 PM
Reverse slam - valve body or input shaft nut?! YouDriveAWhat S-Series Tech 1 03-10-2007 10:49 PM
Had Reverse-Slam did Valve Body Replacement lcd60 S-Series Tech 1 12-13-2006 07:59 PM
Help me find reverse/valve body fix! jasons56 Miscellaneous Tech 3 04-08-2003 01:11 PM
