Old 10-11-2007, 10:20 PM   #1
donaldwebster
donaldwebster is on a distinguished road
Default 07 Aura
The AM portion of the radio is noisy and won't pick up stations 20 miles away.
When you turn on the rear window defogger, it makes static on the radio AM.
Even two of the local channels have static in the background.
ANy ideas. The radio in my old 2000 LS1, had a great radio even the AM would pick up stations at least 100 miles away.
Add to donaldwebster's Reputation
Rate the quality of this post and help donaldwebster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
donaldwebster is offline   Reply With Quote
Old 10-12-2007, 11:54 AM   #2
Seasoned
Seasoned is on a distinguished road
Seasoned's Avatar
2007 AURA XR
2004 ION-2 Quad Coupe
Default Re: 07 Aura
It sounds like your problem may be related to a bad ground, however, there have been issues with the radio that are well documented in other threads on this web site, so you can search and see if you think they are relevant to your issue. Certainly there is now a fix. If you research the threads, I believe there is a Technical Bulletin issued for similar issues
Add to Seasoned's Reputation
Rate the quality of this post and help Seasoned reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Seasoned is offline   Reply With Quote
Old 10-12-2007, 01:54 PM   #3
bdubsee
bdubsee is on a distinguished road
Default Re: 07 Aura
Are your windows tinted?
Add to bdubsee's Reputation
Rate the quality of this post and help bdubsee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bdubsee is offline   Reply With Quote
Old 10-12-2007, 09:14 PM   #4
donaldwebster
Happy Re: 07 Aura
Old 10-13-2007, 06:08 AM   #5
bdubsee
Default Re: 07 Aura
Some window tints contain metal that will interfere with the radio antenna (built into the rear window). The problem will be most acute on AM or when the rear defroster is on. I had this happen two Epsilons ago and learned my lesson.
Old 10-20-2007, 04:07 PM   #6
donaldwebster
Default Re: 07 Aura
The dealer hooked up a regular car antenna to the radio with a antenna adapter. That morning we could pull in 35+ AM station with no static. Put the car antenna plug back in got about 8 and 3 of them were nosiy.
Old 10-20-2007, 07:59 PM   #7
ssicarman
ssicarman's Avatar
Default Re: 07 Aura
Did your Saturn store do a search of bulletins? They should have come up with:
Subject: Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids May Be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) #03-08-44-005G - (03/09/2007)
Condition
Some customers may comment that the radio has poor reception or radio static/increased interference when the rear window defogger is turned on. Also, some rear window defogger grids may be inoperative.
Cause
This condition may be due to microscopic cracks in the electrically heated grids of the rear window defogger. These cracks may cause electrical interference when the rear defogger is on and this could affect radio reception.
Not to mention a couple of others that I eliminated because they did not fit your description of the problem getting worse with the rear defog on.
Add to ssicarman's Reputation
Old 10-24-2007, 09:43 PM   #8
donaldwebster
Default Re: 07 Aura
I have a 2007 Aura XE. Is there a easy way to add a outside car antenna. The one in the rear window is lousy. We hooked a outside antenna to the radio and pull in 30+ AM stations. Only get 8 stations with window antenna, and 3 of them are weak and nosiy. Even worse with the rear defog on.
Old 10-24-2007, 11:11 PM   #9
reno97
reno97 is on a distinguished road
Default Re: 07 Aura
Why don't you plug in a portable radio into the Auxiliary port?
Add to reno97's Reputation
Rate the quality of this post and help reno97 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
reno97 is offline   Reply With Quote
Old 11-08-2007, 10:59 PM   #10
donaldwebster
Default Re: 07 Aura
Thanks to a great Service Dept at Saturn Wichita East (KS). They got my radio problem fixed.
It was a bad cable behind to the dash board.
I've had Saturns since 1994. And they have always had superb service from this Saturn Dealer.
Changes to 08 Aura slv01sc2 Aura General 1 07-05-2007 09:04 AM
Aura XE, Aura XR or Aura GreenLine SCDYNE Aura General 1 05-21-2007 02:28 PM
Drove a Aura XE & Aura XR today...LOTS of pics! psychobueller Aura General 3 08-22-2006 07:20 PM
Aura and Aura GL Engine and Tranny GearGuy Aura General 0 05-19-2006 12:06 AM
Aura vs. G6 Brad LeBosse Aura General 27 04-27-2005 07:29 AM
