Old 07-24-2017, 04:16 PM   #1
KSabo
KSabo is on a distinguished road
KSabo's Avatar
Default 2002 SC2 DOHC - which vacuum hose is this?
What is the small fitted vacuum hose that crosses the valve cover directly below the steering fluid reservoir? I need a replacement one of these....
TIA
Black 2002 SC2 manual 1.9L DOHC - 210,000 miles (July 2017)
KSabo is offline   Reply With Quote
Old 07-24-2017, 05:20 PM   #2
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Re: 2002 SC2 DOHC - which vacuum hose is this?
The one that crosses over and mounts to two studs on the valve cover? Rubber boot on each end?
That's the secondary air injection vacuum harness.
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Claybury is offline   Reply With Quote
Old 07-24-2017, 05:37 PM   #3
KSabo
KSabo's Avatar
Yes, exactly.
Totally unavailable to purchase, apparently. I guess I will have to make one.
Old 07-25-2017, 12:50 AM   #4
Saturn Night
Originally Posted by KSabo View Post
Yes, exactly.
Here is a link to the parts diagram for the A.I.R. System, from GM:
http://www.wholesalegmpartsonline.co...rimLevel=25227
Here is a link to sourcing from a salvage yard:
www.car-part.com
It appears the DOHC harness is NLA(No Longer Available), even from GM. Your best bet is to source a used set of preformed pieces from a dead S-Series at a local yard. Most yards will not pull them off, or scrap them, so see if the yard managers will let you pull it yourself.(It helps of you have good rapport with the yard managers/owners)
Old 07-25-2017, 12:58 AM   #5
Go to a pick and pull yard.
You can buy straight lengths of that hard nylon tubing in a 1/8"-3/16" diameter at NAPA and then buy the soft rubber vacuum tubing to match the nylon tube and make all the bends and connectors out of the soft tubing with the nylon for the straight runs. Old JY parts are all way too brittle to spend much time or money on when you can build a new one in minimal time and expense.
Old 07-26-2017, 08:04 AM   #6
BV22
2002 SC1
Or you can get fancy and bend one out of 1/8" OD hydraulic tubing.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 07-26-2017, 09:03 AM   #7
floridasl22002
As already suggested you could try a JY BUT if yours has broken through age, then its highly likely JY tubing may well be in the same condition.
Most of the Autostores carry tubing of various types, sizes and application , including vacuum tubing. They sell it by the foot. They also sell T and L corner connectors too.
I would suggest popping into the store and take the tube with you and see what they have in their bulk stock. In some cases the new tubing would end up being a gentle curve rather than a molded shape like you have right now BUT if you want to use say a hairdryer, you may be able to warm points on the tubing enough to slightly bend them. It won;t be exactly the same but at least will give you some bends.
When you own an orphan car that's been out of production for 15 years, then you have to be inventive to get by!
Old 07-26-2017, 09:19 AM   #8
3/16" OD brake line works better and is easier to find. Comes in 5' and 6' straight lengths. Is also coated on outside with a thin dark gray plastic.
Old 07-26-2017, 12:53 PM   #9
KSabo
KSabo's Avatar
That's exactly the problem - so old and brittle that it just crumbles... I'm sure the local junk yard DOHC SCs will have the same problem. I have a temporary piece of hose patching mine for now.
Thank you all for the ideas on how best to make a new one and the link to the A.I.R. diagram which is extremely helpful. Got making a new one planned for my vacation in a couple weeks when I am changing out the valve cover gasket.
-Kristin
Old 07-26-2017, 01:47 PM   #10
trottida
trottida's Avatar
You can repair cracks and breaks using heat shrink tubing.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
vacuum hose ?? izzy92p S-Series Tech 2 11-25-2014 11:26 AM
Vacuum Hose Help nitro169 S-Series Tech 1 01-18-2014 11:15 AM
What size vacuum hose to get Chris0381 S-Series General 4 09-23-2011 03:53 PM
Vacuum hose identification cicamuk S-Series General 9 08-24-2011 09:12 PM
Vacuum Hose Locations huntn machine S-Series Tech 4 03-10-2008 05:32 PM
