So as all us Saturn Ion Owners know, the Spare tire Cover in the trunk is that junky material board fiberglass stuff that will break apart with the littlest amount of force applied, so as Oxyhydro of this forum did, I plan on replacing that with plywood and cover it with the original carpeting. another idea i had was because i have a lot of wiring with my Emergency Lights just tucked under seats and things like that so i figured i might as well pull up the floor carpeting and run those wires under there and cut outlet holes for the wires leading to the light heads. also on the bumper there is that plastic divider that splits the bumper in two, which for the only reason i can see is for aesthetic purposes, I want to Cut that out and mount fog lights in there because my headlights are faded to hell. The Final mod i want to do is take some small pieces of plywood and possibly an acrylic sheet with hinges and a handle and make a battery box, because my battery seems to slide around if i take turns too fast. I'll update yall when i start this up. but if you have any other ideas or possible other alternatives to these let me know
Criminal Justice Major Kid With No Car Knowledge |
Fog lights won't replace headlights. Get a good headlight lens restoration kit. It won't make them look brand new, but it will make a big difference.
Headlamps arent expensive to replace either.
As for the battery, there should be a tray the battery goes in to mount it down. Maybe your missing the mount to hold it down
03 ion-2 Sedan 5sp 94 Honda civic automatic "VTEC yo" 05 Santa Fe 2.7L (Fefe) {Wrecked} "A problem clearly stated, is a problem half solved." ♕KCCO |
ideas welcome | spacetrace33 | S-Series Tech | 11 | 09-12-2013 12:26 AM |
looking for HP mod ideas plz help | skitzo | Ion Mods | 4 | 11-18-2008 06:30 AM |
Any ideas? | StarrAuto | S-Series Mods | 8 | 06-04-2008 08:39 PM |
Out of Ideas...??? | Mdawg2009 | S-Series Tech | 27 | 05-12-2008 05:45 AM |
Oil pan..help!! Need ideas? | 1993 | S-Series Tech | 3 | 03-26-2006 04:44 PM |
