Old 04-07-2007, 09:50 PM   #1
Dan76
Dan76 is on a distinguished road
Dan76's Avatar
1999 SL
Dizzy Removing the door trim panels
Oops!! I posted this over in the wrong section, so I am reposting it here....
How hard is to remove the front door panels in a 99'' SL? Is there any ''special tools" I need? I am looking replace my factory speakers here soon.
Any tips? Ideas for removing the door panels without destorying them?
Dan76 is offline   Reply With Quote
Old 04-07-2007, 09:52 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Removing the door trim panels
Here ya go:
http://spocnorth.com/HowToSite/DIYGu...rDoorPanel.htm
DIY guide with pictures.
Old 04-07-2007, 10:01 PM   #3
Dan76
Dan76's Avatar
1999 SL
Originally Posted by PurdueGuy View Post
Here ya go:
Thanks but, I don't have power locks or windows like the one in the picture. How do I remove the manual door handle?
Old 04-07-2007, 10:26 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
the door handle, or the window crank? The door handle will be the same, minus the power door lock harness. I've not messed with the window cranks before, sorry. I think they are probably held in by a clip behind the crank, and have seen "removal tools" in parts stores before. Sorry I can't be more specific.
Old 04-07-2007, 10:28 PM   #5
Dan76
Dan76's Avatar
1999 SL
Window crank. I think the door handle comes off with screws.
Old 04-08-2007, 05:27 AM   #6
SaturnManiac
SaturnManiac's Avatar
Removing the window crank is fairly easy, you can probably just stick a thin flat-blade screw driver behind the crank (I have done this before) and there should be a little clip, and this should release it....be careful though...so it doesn't fly too far. Once that clip is removed the crank handle should easily just slide off. Make sure you don't lose the clip, you will need to put this back on during re-assembly.
about removing your door panels metgol Aura General 2 04-28-2008 04:23 AM
removing door panels jrburkla Vue General 4 04-06-2007 05:27 PM
Removing 96 SL door panels flatlander4510 S-Series General 3 03-23-2005 02:24 PM
Removing Door Panels -- skeeter1001 S-Series Tech 5 05-31-2003 05:07 PM
Removing door panels SL2Master S-Series Mods 7 12-23-2002 10:27 PM
