Old 01-17-2006, 12:20 AM   #1
gypsy35
gypsy35 is on a distinguished road
Default stumble on take off again
well heres what i have done, changed my fuel filter, pump, changed oil, transmission oil and filter, changed ect and wire, pcv valve, changed plugs and wires, had a code check , nothing, all done by dealership, except oil changes. also had a tune up,checked egr and coils and wires and vaccum leaks, still stumbling on take off, shifts fine, also idles fast sitting still and going to a stop.
gypsy35 is offline   Reply With Quote
Old 01-17-2006, 02:38 AM   #2
stanleyr
stanleyr is on a distinguished road
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Default Re: stumble on take off again
Some ideas...
Fast idle: Really low coolant temp; coolant temp sensor is shot; PCV hose is brittle and leaking; MAP hose (if your's is remotely mounted) is brittle and leaking; IAC is sticking
Stumble: EGR valve is not closing at idle; MAP sensor is giving poor vacuum readings (thinks your throttle plate is open like on the highway); TPS is giving false readings (but would typically give a code)
Good luck
stanleyr is offline   Reply With Quote
Old 01-17-2006, 10:13 AM   #3
BarnOwl
BarnOwl's Avatar
I'd bet on the coolant temperature sensor. On a 2000 just replace it. Whether it's bad now or not, it's going to go sometime soon.
stumble at 55 speed150 S-Series Tech 2 06-26-2008 12:38 PM
Occasional Stumble geeminator S-Series Tech 4 04-24-2006 07:31 AM
Stumble At startup katarn444 S-Series General 18 12-16-2005 10:11 AM
Subtle stumble...cause? schultp S-Series Tech 2 11-10-2005 07:05 PM
Engine stumble dixonba Miscellaneous Tech 7 08-13-2004 08:49 PM
