Old 12-27-2005, 05:28 PM   #1
djmikeyz28
djmikeyz28 is on a distinguished road
Default Removing Door Trim on '97 SL2
I'm putting in an amp and subwoofer in my '97 SL2. I've already run the power wire through the firewall. I'd like to run the wiring underneath the inner door trim at the bottom but I'm not sure how to get it off without breaking it. There's no screws, so there must be clips inside, but I'm not sure which way to pull so that I don't break it. Lil' help!?
1996 Black Camaro SS A4
Flowmaster Exhaust, shift kit, MagnaFlow Cats, Mobil 1 Synthetic, Chrome ZR-1 Wheels, bright red calipers.
http://www.cardomain.com/ride/1878338
djmikeyz28 is offline   Reply With Quote
Old 12-27-2005, 07:50 PM   #2
S3aturnR
S3aturnR's Avatar
1999 SL1
Default Re: Removing Door Trim on '97 SL2
those are all pressure clips. you need to carefully pry them with a screwdriver. make sure it's warm where you're doing it or it will break real easy...
s3aturnr
Old 12-28-2005, 01:15 AM   #3
djmikeyz28
Do I want to try to pry them from the top or from the bottom? I tried to pry them off from the top and it felt like something was going to break.
Old 12-28-2005, 01:34 PM   #4
S3aturnR
S3aturnR's Avatar
1999 SL1
you gotta work the screwdriver carefully about halfway thru, then slide it along the length until it runs into something. don't just put it at the top or bottom, it will break for sure. after i'd done it a few times, i could just work my fingers under the bottom and feel where those clips are and just pull straight out (towards the center of the car)...
s3aturnr
Old 01-07-2006, 04:38 PM   #5
djmikeyz28
Just got around to finishing this project today... finally got some nice weather. Thanks for the help, those clips are jerks. Probably never been off on my car, so I had to really rip them out, but they didn't break.
Removing the door trim panels Dan76 S-Series General 5 04-08-2007 05:27 AM
Removing Trim? Jeff K S-Series General 7 03-19-2006 11:14 PM
Removing Inner Door Trim androol S-Series General 1 11-17-2005 11:20 PM
Trouble removing outer rear door panel on 1997 SL2 kmcgillivray S-Series Tech 2 09-07-2004 07:27 AM
Trouble removing outer rear door panel on 1997 SL2 kmcgillivray S-Series General 2 09-06-2004 07:02 PM
