Old 01-29-2005, 03:32 AM   #1
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Internal Engine Cleaning
Hey all, tomorrow i figured I'd "cleanse" the inside of my engine, by this i mean:
I will do a standard oil change but refill it with 1 quart of MMO and 4 quarts of Full Synthetic Mobil 1, seeing as how synthetic "cleans" the enigne. This is the first time i wlll be running full syn.
With this said, how long should i run it before the next oil change? if this stuff is gonna loosen up all the gunk i know i don't wanna run it with this stuff in the system for long. 500 miles? 1000 miles?
thanks.
RalliArt16 is offline
Old 01-29-2005, 05:39 AM   #2
kev-inc
kev-inc is on a distinguished road
Default Re: Internal Engine Cleaning
Mobil1 itself will do a pretty good cleaning job. Just change it at a normal interval. Mobil1 has been known to last 5k-10k miles is many cars depending on your driving.
I like using a product called Auto-RX. I have used it in my saturn and it got a lot of junk out of the engine.
more info at:
http://www.auto-rx.com/
many pleased users at this "Bob is the oil guy" forum: http://theoildrop.server101.com/ubb/ultimatebb.php
Pic of my saturn oil.
http://theoildrop.server101.com/cgi/...c;f=5;t=002762
kev-inc is offline
Old 01-29-2005, 12:01 PM   #3
Razorbak
Razorbak's Avatar
thanks.
The engine is supposed to hold 4 quarts, so you're going to be 1 quart high. Not good.
Razorbak is offline
Old 01-29-2005, 06:16 PM   #4
schultp
schultp is on a distinguished road
Since most S-series Saturns burn a little oil. Why not add the quart of MMO prior to the oil change? Run it for another week (at least a couple hundred miles) and then change the oil over to strictly Mobil 1.
Just an idea.
Paul.
schultp is offline
Old 01-29-2005, 07:02 PM   #5
emptypockets
emptypockets is on a distinguished road
emptypockets's Avatar
1999 SC1
thanks.
Yeah I was thinking the same thing. A friend of mine ran his car with a little too much oil(I wanna say like 3 quarts) and it didn't turn out too great.
emptypockets is offline
Old 01-29-2005, 07:27 PM   #6
Dr. Bob
Dr. Bob is on a distinguished road
Where's Wolfman when you need him???
Seriously, you MAY be able to run ok with 1/2 quart overfill, but a full quart is not a good thing to do. Too much oil can cause excessive frothing and aeration of the oil which can actually reduce lubrication efficiency and worsen oil consumption.
Better to check your oil at every fill of gas if you have an oil user.
I'd agree with the Mobil 1 cleaning gunk out of the engine all by itself. I converted my 99SL2 at 62,500 and the the first change was done early because the M1 got dirty unusually fast. The second fill of M1 was normal. The third fill remained clean longer still.
I don't think I'd run a full quart of MMO for an entire 2,500 or 3,000 mile change interval due to its relatively thin viscosity. Maybe put in a half quart or a quart (if there's room to do so) 500 miles or so before you change it would be a better approach?
Dr. Bob is offline
Old 01-29-2005, 09:15 PM   #7
wolfman
wolfman's Avatar
I think I actually responded to a similiar post a few weeks (months?) back.
DOHC (Has OIL BAFFLE PLATE) can be run "safely" up to 1 quart over full.
SOHC (NO OIL BAFFLE PLATE) 1/2 to 3/4 MAX before you will get issues like foaming and increased burn off.
There is also a fairly extensive post about oil additives....If you want to add about 12oz or so of MMO to help clean things out before the next oil change, it will help, BUT I would not leave it in there for more than 250-500 miles or so MAX.
wolfman is offline
Old 01-29-2005, 10:04 PM   #8
Dr. Bob
Gee Wolfman, I set you up for your signature line... but alas you didn't bite!
Dr. Bob is offline
Old 01-30-2005, 12:38 PM   #9
Razorbak
Razorbak's Avatar
I agree, but there's no benefit from running 1 quart high, especially when he's planning to dump the oil within 500-1000 miles. Why throw away a full quart of Mobil 1 for no good reason?
Razorbak is offline
Old 01-30-2005, 02:12 PM   #10
RalliArt16
RalliArt16's Avatar
1996 SC1
LOL my bad everyone.. didn't mean to get attacked by making an error and saying i was gonna run 5 quarts I just add oil up to the FULL line on the dipstick... and i just assumed this was 5 quarts like the typical engine
Old 01-30-2005, 06:50 PM   #11
Razorbak
Razorbak's Avatar
Nobody attacked you.
Razorbak is offline
Old 01-30-2005, 08:18 PM   #12
Ah, but that's the thing; 5 quarts isn't "typical". EVERY four-banger I've owned or worked on has called for 4 quarts of oil. But yeah, in decades passed, it seemed like EVERY engine, from a little 200 I-6 in a Maverick to a 383 Chrysler, took 5 quarts.
madpogue is offline
Old 01-30-2005, 09:16 PM   #13
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
the Ecotec 2.2 is a 5 quart engine
the Trailblazer 4.2 six has 7 quarts
more oil is good......if the engine is designed for it.
as far as internal cleaning, over on www.bobistheoilguy.com they seem pretty sold on a product called AutoRX
Bill Murray is offline
Old 01-30-2005, 10:45 PM   #14
wolfman
wolfman's Avatar
I will only chime in to say that while Auto-Rx appears to work, it is expensive, and I am somewhat wary of a product that as part of it's instructions tells you to essentially keep buying it and pouring it in basically forever....
wolfman is offline
Old 01-31-2005, 03:39 AM   #15
kev-inc
Yes it's expensive but, I am a believer now. A lot of nasty stuff came out of my Saturn. Not much came out of my integra though Both cars run noticeable better especially the integra. The saturn hardly burns oil anymore. Before it would burn 1qt every 3K.
I think one treatment is enough. The second treatment just puts money in their pocket.
kev-inc is offline
Internal Engine Oil Cooler '03 Vue E3019583 Vue Tech 8 10-23-2009 10:17 AM
Engine internal solvent cleaning, generally... TomM96 S-Series Tech 7 02-01-2009 08:01 PM
Saturn Internal Cleaning TSB Lucas1 How-To Library 28 10-17-2005 08:51 PM
(Saturn TSB 99-I-08; June 1999, "Internal Engine Cleaning Products," All Saturn Vehic rtfm17 Miscellaneous Tech 9 07-31-2003 10:48 PM
Engine cleaning (internal) 100KSW2 S-Series Tech 7 02-06-2001 07:31 AM
