Old 12-30-2004, 12:34 AM   #1
Saturnaddict
Saturnaddict is on a distinguished road
1994
Dazed slightly confused
i just got a 94 saturn but don't know the model. how do i tell??! Also, how do i swap the head of a dohc into a sohc engine?
Saturnaddict is offline
Old 12-30-2004, 01:43 AM   #2
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default Re: slightly confused
You're quick to be an addict if you just got a Saturn!
SOHC coupe = SC1
DOHC coupe = SC2
SOHC sedan = SC1
DOHC sedan = SC2
SOHC wagon = SW1
DOHC wagon = SW2
Before 1993, the SC1 and SC2 didn't exist. It was simply called the SC and came with a DOHC engine.
SLeepr is offline
Old 12-30-2004, 01:57 AM   #3
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
SOHC coupe = SC1
DOHC coupe = SC2
SOHC sedan = SC1
DOHC sedan = SC2
SOHC wagon = SW1
DOHC wagon = SW2
Correction, sedans are SL1 and SL2 accordingly. Yeah I know you just mistyped. It should say on the valve cover I think if its SOHC of DOHC. Or if your car is slow as balls its an SOHC.
'01 SC2 - sold
Bigbadbert is offline
Old 12-30-2004, 02:04 AM   #4
SLeepr
SLeepr's Avatar
Dang, I have to get the strings from my brain to my fingers checked. Good catch.
As far as the second part of the question, I'm going to assume you have a SOHC motor right now. While you can do a head swap and use the SOHC bottom end, I would just swap motors instead. It's probably easier in the long run and could save you some headaches. Look for a low-miles, used motor with a warranty (if you can get one). You will also need to make sure that the PCM and wiring harness jive with your motor. There should be a few posts about motor swapping on here. Do a search for the play-by-play.
SLeepr is offline
Old 12-30-2004, 02:05 AM   #5
GmG
GmG is on a distinguished road
GmG's Avatar
1992 SC
When I got my first Saturn I didn't know the difference between SL, SL1 and SL2. Now I find myself calling people about Saturns for sale and asking things like "Are the bumpers the same color as the car?" or "Does it have pop-up headlights?" because single cam/dual cam doesn't seem to mean much to most people.
George
GmG is offline
Old 12-30-2004, 11:59 AM   #6
mars_volta
mars_volta is on a distinguished road
mars_volta's Avatar
heres a good guide to what you have....
half way down...
http://www.turbosaturns.net/forum/viewtopic.php?t=2211
yep. if you put a dohc head on a block with sohc pistons, youll end up with slightly lower compression.. not what you want non turbo..
mars_volta is offline
Old 12-30-2004, 12:42 PM   #7
Saturnaddict
1994
i did have an sl1 a couple years ago, then i wanted to go honda or somethin cause i sold the car but i just couldn't stay away from saturns. i know the diff between sl, sl1 & sl2, but don't know how to differentiate between engines since i forgot what the saturn dohc looks like. this thing doesn't have much of anything tho, i think it may be a sohc.
Old 12-30-2004, 12:47 PM   #8
Saturnaddict
1994
Sad Re: slightly confused
dang, nevermind it's a sohc
Old 12-30-2004, 05:36 PM   #9
freakerz
freakerz is on a distinguished road
freakerz's Avatar
Welcome to my world of pain.
freakerz is offline
Old 12-30-2004, 06:15 PM   #10
sierrap615
sierrap615's Avatar
SOHC coupe = SC1
DOHC coupe = SC2
SOHC sedan = SC1
DOHC sedan = SC2
SOHC wagon = SW1
DOHC wagon = SW2
change that to:
SOHC sedan = SL1
DOHC sedan = SL2
and don't forget
SOHC sedan base = SL(easiest way to tell - no rear speakers)
sierrap615 is offline
Old 12-31-2004, 05:59 AM   #11
Bigbadbert
Bigbadbert's Avatar
Yeah we got that already. Just do an engine swap! Its worth it.
'01 SC2 - sold
Old 01-01-2005, 05:11 PM   #12
Saturnaddict
1994
how difficult, tho, on a frustrating scale of one to ten?
Old 01-01-2005, 08:44 PM   #13
ProDarwin
ProDarwin is on a distinguished road
If you are mechanically competent, 3. Otherwise, 8.
Actually changing the engine and trans is real easy. For me the hardes part is probably the instrument cluster, which isn't that bad.
-Travis
ProDarwin is offline
Old 01-02-2005, 04:17 AM   #14
freakerz
freakerz's Avatar
Yeah I fear doing a swap just for the eletrical part
And when you mean the SL is differentiable by no rear speaker.. you mean no rear DOOR speakers? cuz my SL has rear(under the back glass) speakers
freakerz is offline
Old 01-03-2005, 02:09 AM   #15
Saturnaddict
1994
back to the dohc on sohc bottom end-how much lower will that make my compression? i've got a '93 dohc from junkyard. what can i do to get that compression back?
Old 01-03-2005, 06:47 PM   #16
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
it will give you about an 8.5 ish to 1 comp ratio
thats low for n/a, decking the head can help bring it back up though
TheSaturnKid is offline
Old 01-03-2005, 07:22 PM   #17
tsrygley83
tsrygley83 is on a distinguished road
Even if you deck the head to the service limit, it will still have less than stock compression. Be better, and probably cheaper to just buy some DOHC pistons.
tsrygley83 is offline
Old 01-03-2005, 07:27 PM   #18
TheSaturnKid
I always wondered, what about decking the block and the head to achieve a larger material amount, taken off?
Old 01-03-2005, 07:32 PM   #19
tsrygley83
If you take more than a total of 0.050" out of either one of them (combined 0.050"), the timing chain tensioner won't really work any more, so it would be pointless.
Old 01-04-2005, 12:36 PM   #20
Saturnaddict
1994
Valves:
91-94 Valves; Flatfaced. Compatible with 91-98 cylinder heads.
95-98 Valves; Dished. Compatible with 91-98 cylinder heads.
91-93 had flat faced valves.
94+ had dished valves.
Now what difference does it make? The 91-93 can be used to raise the compression slightly on the 94+ model years. While the 94+ valves can be used on 91-93 years to lower compression slightly.
so if i use a 93 dohc head w/ a 94 sohc bottom end, will that help w/ comp?
Pulling slightly right marx404 Astra General 31 08-12-2019 08:24 AM
A slightly different vibration question sl2gold S-Series Tech 9 11-17-2008 08:57 AM
Slightly Moody Transmission CND_SC1 S-Series Tech 1 06-30-2006 12:10 PM
Wheel slightly off center rkuris S-Series Tech 5 05-23-2005 09:56 AM
Portable refrigerator (slightly o/t) gaf3 Vue General 18 07-21-2003 11:46 PM
