Old 11-25-2004, 10:25 AM   #1
sly_h
sly_h is on a distinguished road
Default Secondary Air Injection System Malfunction
Hi All,
I was wondering if any of you have ran into this,
I have a 99 SL3 and I keep getting code P0410 Secondary Air Injection System Malfunction
Do you know what it is and how I can remedy it?
Thanks,
sly
sly_h is offline
Old 11-25-2004, 11:40 PM   #2
Default Re: Secondary Air Injection System Malfunction
Welcome to the Board.
What is setting the code is that the O2 sensor is not seeing a lean condition when the air pump is running. Maybe more specificly when the air pump is suposed to be running.
to diagnose you need a tech 2 scan tool to run a special test. Best that you can do with out is to check that the air pump is working, usually kicks in on start up, and that all the electrical and vacuum connections are good.
ssicarman is offline
Old 11-25-2004, 11:43 PM   #3
wolfman
wolfman's Avatar
The "secondary air injection system" is a small electrically operated air pump that is plumbed into the exhaust manifold. Under a signal from the PCM the "pump" comes on an injects air into the exhaust manifold. The PCM looks for an increase in O2 at the O2 sensor as an indicator that the pump came on when commanded. If the pump does not come on.... Possible causes:
Bad pump
Obstructed or disconnected pump to manifold air supply tube
Bad or disconnected wiring to pump
Failing FRONT O2 sensor
wolfman is offline
Old 11-26-2004, 10:53 PM   #4
Specialist
Specialist will become famous soon enough
Specialist's Avatar
Originally Posted by sly_h
Hi All,
Thanks,
sly
Here is a site that explains secondary air injection, if you are interested in what it does...
http://www.12v.org/engine/index.php?section=hw&sm=2nd
Specialist is offline
Old 11-28-2004, 08:59 PM   #5
sly_h
Thanks!
sly
sly_h is offline
secondary air injection system!?!?!?! sl2ner08 S-Series Tech 11 06-10-2015 09:56 PM
P0410 Secondary Air Injection System Malfunction on 2002 SL-2 HotCookCpl S-Series Tech 20 02-24-2013 12:35 AM
secondary air injection system fault scalemechanic S-Series General 13 01-18-2012 12:46 AM
secondary air injection system!?!?!?!!! sl2ner08 S-Series Tech 3 11-01-2008 06:14 PM
Fixing the Secondary Air Injection System on a 1999 SC2 akasnacker S-Series Tech 3 05-27-2008 07:59 PM
