Old 01-21-2004, 10:49 PM   #1
fgwinn
fgwinn is on a distinguished road
Default Need help removing the trim around front courtesy lights.
I am trying to install a cell phone hands-free microphone somewhere near the courtesy light assembly. I would like to remove the entire assembly with the front courtesy lights and sunroof switch. It seems that this should be a simple matter since you should be able to change courtesy light bulbs. Has anybody successfully removed this assembly?
fgwinn is offline
Old 01-23-2004, 09:59 PM   #2
fgwinn
Default Got it!
After several attempts I figured out how to pop off the courtesy light assembly (near the rear view mirror) on the 2004 Vue.
1. DO NOT pull down on the rear edge. After you unsnap the sides and front edge you need to slide the entire assembly forward to release the rear edge.
2. Gently pull down on each side edge to release the clips. One on each side.
3. Pull down the front edge (the edge towards the windshield). This requires more force since there are two clips about 1.5 inches apart near the front edge.
4. Slide the assembly forward to release the rear attachment point.
I will post pictures as part of the cell phone handsfree kit install that I am documenting.
fgwinn is offline
Old 01-24-2004, 10:33 PM   #3
fgwinn
Default Re-install is not easy...
I completed the modification to the courtesy light assembly to accommodate the cell phone microphone. It's even more difficult to re-install the light than it is to remove it. The snap clips on the front edge require a lot of force to push into place. The headliner is not very solid and just flexes when you try to push the clips into place. I finally managed to get the clips to snap in by wedging a screwdriver in above the plastic trim above the headliner while I applied pressure on the trim below the headliner.
If any one has a manual that explains how to change the courtesy lightbulbs I would be curious to know what is says.
fgwinn is offline
Old 01-24-2004, 11:36 PM   #4
The Math God
The Math God is on a distinguished road
The Math God's Avatar
Default
keep the info on the micorphone coming.
As cold as it has been here in Ohio the past few days (it is 3 right now) , I am impressed by your efforts.
2007 Vue -- AWD 3.5 Honda
2005 Vue -- AWD 3.5 Honda
2007 Ion 2 -- 2.2
2005 L300 -- 6 cyl
Gone but not forgotten
2003 Vue -- 105K-traded in
2000 LS 2 --140 K-totaled
1994 SL-- 100K-sold
The Math God is offline
Old 01-24-2004, 11:51 PM   #5
fgwinn
Default Confession...
I have a gas heater in the garage. I am not looking forward to seeing the gas bill next month. I am not quite crazy enough to freeze to death installing the cell phone car kit.
fgwinn is offline
Door Courtesy Lights are in Layoira Astra General 20 04-23-2014 01:40 PM
Courtesy lights VUESBROTHERS Outlook General 6 12-19-2009 02:24 PM
Door Handle courtesy lights Layoira Astra General 8 12-27-2008 11:26 PM
courtesy lights, defog timer not keeping time jym L-Series Tech 7 10-05-2007 09:54 PM
Removing Trim? Jeff K S-Series General 7 03-19-2006 11:14 PM
