Old 03-25-2020, 08:51 PM   #1
odiaz1831
odiaz1831 is a jewel in the roughodiaz1831 is a jewel in the roughodiaz1831 is a jewel in the rough
2003 ION-3 Sedan
Default Solution to TB to Purge Solenoid vacuum line?
This line fully broke off on me. I've gone to junkyards and they're all broken. It's frustrating. Right now trying to epoxy some, but has someone maybe 3D printer a connector or something where we can use regular vacuum line
odiaz1831 is offline   Reply With Quote
Old 03-29-2020, 12:09 AM   #2
TomM96
Default Re: Solution to TB to Purge Solenoid vacuum line?
Soooo, does your query concern the, black nylon pre-formed tubing that runs down from 'rubber' 90-degree bends on the Rear of the throttle body?
Some guys have used copper tubing -- tubing is specified by its Outside Diameter. It is available from old-line auto parts, and plumbing supply houses.
Can maybe buy some nylon tubing from McMaster-Carr Supply:
https://www.mcmaster.com/
https://www.mcmaster.com/nylon-tubing
Throttle Body Evap Canister Purge Solenoid Line gveinot S-Series Tech 0 05-02-2016 10:17 PM
Shocking discovery - EGR solenoid instead of purge solenoid StarLady S-Series Tech 11 07-29-2010 08:08 PM
Thanks! (EGR/Purge solenoid help.) zatoh S-Series Tech 1 03-24-2008 03:03 AM
93 SL2 Purge Solenoid Partymmudasti S-Series Tech 2 11-20-2005 09:16 AM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
