Old 03-01-2020, 08:27 PM   #1
chris's sc1
chris's sc1 is on a distinguished road
Default Fuel tanks
Will a 96 sl2 tank fit in a 2000 sl2.
chris's sc1 is offline   Reply With Quote
Old 03-01-2020, 09:21 PM   #2
Default Re: Fuel tanks
Doubtful as '96 is gen 1 and '00 is gen 3. Might work if you find a '97 which is gen 2 (the 2drs change gen different than the 4dr's).
Or you can save yourself the effort and just swap the pump module as that's the only place the fuel goes in & out...
Old 03-01-2020, 10:26 PM   #3
chris's sc1
I'm curious because I'm swapping a 96 motor into a 2000 car. Since the 96 has fuel return and the 2000 doesn't. I'm trying to find a way to make it happen. Seems the most logical way is to swap tanks. So I can swap lines as well.
Old 03-02-2020, 02:34 AM   #4
onlinebiker
96 is Gen2 in my book.. Although it does still have the return line....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 03-02-2020, 10:50 PM   #5
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
98-02 fuel tanks are slightly smaller than 91-97 and seem to be a different shape based on the part diagram. It is kind of hard to tell from 2 different angles though
91-97 fuel tank
98-02 fuel tank
97 SL2, auto, 118K miles
Old 03-04-2020, 01:15 AM   #6
chris's sc1
They do look a little different in shape. But looks like it might fit. If I could get a cheap on I'd try to install it
Old 03-04-2020, 02:43 AM   #7
This is the only thing, other than the filler neck & vent pipes, that let gas into/out of the tank. This is all you need to swap.
Old 03-06-2020, 06:35 PM   #8
chris's sc1
Ok so I swap pumps. What about lines, does 96 model lines fit a 2000.
Old 03-22-2020, 03:08 AM   #9
TomM96
Well the lines on my '97SW were routed differently along the body-pan
than on my 2000SW, a bit different in the engine compartment... and of course the fuel filter on the '97 was inside the front wheel, while on the 2000 it is just ahead of the fuel tank under the body pan.
Aluminum radiators...yes even the tanks. dwillimon S-Series General 34 04-04-2016 09:09 PM
are there radiators with aluminum tanks? SL2nitsua S-Series Tech 3 06-03-2014 12:10 PM
Drilling gas tanks for gas in SC BobbyP General Saturn Discussion 7 03-20-2011 06:21 PM
co2 tanks ? carl S-Series Mods 9 07-27-2006 11:53 AM
FREE gas tanks for a 1993 SL1 between5and7 Classifieds 0 09-12-2004 01:32 AM
