Old 05-20-2016, 04:07 AM   #1
ticla
ticla is on a distinguished road
Question window switch
ion 2007 driver side electric window
sometimes the window dosent want to raise.
i wait 2 or 3 minutes minutes and it start to work fine.
intermittent problem.
all other windows work fine
Saturn ION 2007
75,000 miles
2.2 echotech
ticla is offline   Reply With Quote
Old 05-20-2016, 06:22 AM   #2
billysvue
Default Re: window switch
electrical: Intermittent contact- try electronics contact cleaner(plastic safe)
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 05-22-2016, 08:05 AM   #3
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
May be chafed or broken wire(s) usually in/around the door's rubber boot between the Door and frame. Some methodical testing of all your door switches may also show a problem with other Door Locks,mirrors, and/or the other Windows. Sometimes only when affected Door is Open, Half Open/Closed, or Closed.
Basically if it is an Electrical short just be prepared to not have any of those functions as testing may increase the chances of the problem(s) getting worse. Had a Power Lock switch failure on the Driver's side door. Easy enough to ignore. Eventually lost power mirrors (also not too bad) but when I couldn't control any Windows from the Driver's side... it was time to fix. Had to patch up a lot of cracks and breaks. So I suppose if you catch it sooner rather then later you can do some preventive maintenance... (I got everything but Power Mirrors back after my repairs... So not sure if I miswired,missed a short, and/or had a new break when reinstalling the boot/wires.)
lgodave is offline   Reply With Quote
Old 06-03-2016, 06:04 AM   #4
ticla
Thumbs Up Re: window switch
thanks a lot for your answer
I did buy a new door switch and solve my problem.
Saturn ION 2007
75,000 miles
2.2 echotech
Bad Window Switch...how raise power window before I get part? flyhop S-Series Tech 3 08-06-2012 09:44 AM
Window Switch Take Apart jswingchun S-Series Tech 1 04-24-2011 01:20 PM
Possible to mod window switch? Elementkng20 Ion Mods 7 07-29-2009 10:47 PM
Window switch STLWACO S-Series Tech 8 11-28-2006 05:45 PM
Window Switch LED's pruitts Vue General 5 09-23-2004 07:37 PM
