Old 04-17-2016, 08:32 PM   #1
mtnbob
mtnbob is on a distinguished road
Default 2005 Ion stopped suddenly
My 2005 ion stopped suddenly, about a minute after starting it. It is a 2.2 liter engine. Now when I turn the key, nothing happens. lights come on, but no sound of the starter even clicking. Engine is not locked up, starter will try to start when direct power is put to it.
When a odb2 reader is hooked up, it shows a communication error. It is getting no info at all. Fuses all look good and I switched some around to double check. Any suggestions would be appreciated. ECM maybe? anything else I should check for?
Thanks in advance.
I might add that I had the ignition switch and electric steering replaced under recall about 6 months ago at the dealership.
mtnbob is offline   Reply With Quote
Old 04-18-2016, 08:11 PM   #2
mtnbob
Default Re: 2005 Ion stopped suddenly. Won't turn over.
I have been reading all of the "car won't start, and car shuts off" posts for days, but not really seeing the same thing. If It is obvious and I'm missing it, please tell me. I am seeing everything on the dash start up when I put the key in and turn on car.It has a fully charged battery. When key is turned to start car nothing happens. No clicking of starter. ECM tester is reading no connection. It searches for awhile then returns a no connection code. On the dash it is flashing "coolant" and "power steering". Checked connections of ECM. Checked the fuses under the dash. They all looked good, but maybe they go without a tell-tale sign?
Suggestions on next steps in diagnosis? I have had this car for 3 years and had power steering issues about 6-7 months ago which were fixed with the recall. They also replaced the ignition switch and gave me new keys. Never had another problem until this.
BTW my Ion is a 5 speed
Old 04-18-2016, 10:56 PM   #3
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
i'm thinking everyone is stumped here.
i would check all the fuses regardless how they look. you need to make sure 12V gets to ECU.
fixed/replaced so far: side mirror, window trims x4, trunk floor, radiator bushing, alternator, starter, LCA x2, sway bar bushings x2, end links x2, timing chain tensioner, O2 sensor.
jacek_p is offline   Reply With Quote
Old 04-18-2016, 11:11 PM   #4
mtnbob
Ok ty will check each one out.
Old 04-19-2016, 01:25 AM   #5
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Is their 12 volts at the starter large cable and engine block ground with headlights, HVAC blower on and ignition in run position?
Old 04-19-2016, 12:05 PM   #6
2006 ion2
2007 ION-2 Sedan
These cases so this when your ecu and/or front lighter fuse (no communication error) are blown. Have you checked both fuse boxes?
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 04-20-2016, 12:04 AM   #7
mtnbob
I will check all suggestions on Friday and report back!!
I am a special Ed teacher, and swamped during the week
Old 04-20-2016, 01:21 PM   #8
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
As 2006 ion2 mentioned you might not have 12v power in the Front Power Outlet if that fuse blew (which is located in the Fusebox behind the kick plate next to gas pedal by the Central Instrument Panel). If you have a Car Phone Charger you'll know rather quickly if that fuse is bad... (the rear power outlet is on a separate fuse and may be switched, staying on when Key is "ON" or after it's switched off within 10 minutes and the door(s) stay closed)
lgodave is offline   Reply With Quote
Old 04-22-2016, 03:44 PM   #9
mtnbob
I do have power to the front 12volt plug. I checked it last night
I will check the other things tonight if it stops raining.
A/C suddenly stopped working lost_wreckage S-Series Tech 36 06-10-2014 07:45 PM
96 SL-1 suddenly stopped charging papaul S-Series General 1 08-12-2009 09:58 PM
2000 SL2 A/C suddenly stopped working, and lo pressure side shows 100 psi (!?) silk1976 S-Series Tech 17 07-30-2009 08:44 AM
1992 SL1 not starting/stopped suddenly amrjohal S-Series Tech 4 05-02-2008 09:55 AM
car suddenly stopped ~91SL2~ Miscellaneous Tech 2 08-03-2000 10:32 AM
