Old 10-24-2015, 11:54 AM   #1
ghawthorne
ghawthorne is on a distinguished road
Default 1998 SL2 Sedan - Rotted Subframe Danger?
Hi all! Back again about my winter beater. I bought a '98 SL2 a couple weeks ago, paid $750, just looking for something to limp through til the snow melts, then it can fall apart.
Since I got it from a friend of a friend and it only has to survive til April, I took the PO's word that it just needed a front driver's side tie rod.
Turns out that yeah, it does, but also the front subframe just ahead of that tie rod had rust-rotted through so there was about a one-inch gap. A Mavis mechanic showed me how the whole wheel was shifting around while driving.
Another friend welded a couple of foot-long pieces of L-shaped 3/16" thick steel across the gap, and welded around where rusted metal had separated from a bolt further up in the frame. Pics below of the gap and the bolt before the welding job - the big hunk of metal to the side is a sledgehammer head we used to help the jack reach. We were just trying to make sure it at least wouldn't fall apart on the drive home.
I was only planning to drive this thing once or twice a week about five minutes to the grocery store or similar short trips through the winter. What I'd like to know is, is this car now too dangerous to drive and I shouldn't risk myself and others by putting it on the road? What is likely to happen? I can cut my losses and just part it out or something, but I'd like to know if it can survive for such limited use.
Thanks in advance for your help!
ghawthorne is offline   Reply With Quote
Old 10-24-2015, 12:51 PM   #2
billr
Default Re: 1998 SL2 Sedan - Rotted Subframe Danger?
How about pix after the weld repair?
Old 10-24-2015, 04:50 PM   #3
ghawthorne
Ack, yeah, that would've been a good idea.
This is the best shot I could get without driving back to where the ramps were...it's two pieces of L-shaped metal running lengthwise across the gap, back to back. We ground down the rust first to get a bite on good steel before welding.
Old 10-24-2015, 04:59 PM   #4
That's probably the sturdiest part of the car now as the L brackets are thicker than everything else the car is built on
Not sure how well you can get anything welded to multiple thin layers of steel like the subframe is built of but it should hold for the winter as long as you don't do anything extra "interesting" with it...lol
Old 10-24-2015, 07:21 PM   #5
billr
^^^ +1
Old 10-25-2015, 02:28 AM   #6
el diablo viejo
el diablo viejo's Avatar
1994 SW1
That should keep the car going straight through deep snow
97 sl2 a/t 104 K
Old 10-25-2015, 11:19 AM   #7
ghawthorne
Thanks guys! I'm definitely granny-driving it, and only when necessary.
el diablo viejo: You mean steering wise, keeping the car going in a straight line? Will it put too much stress on that part of the frame, tie rod, etc, trying to steer through snow?
This is the kind of stuff I'm trying to find out - I'm a repair/car newbie in general, and I've heard things from "wheel could fall off" to "engine could drop out", so I'm looking for info to know what real dangers/problems to expect.
Old 10-25-2015, 11:44 AM   #8
billr
I think that was kind of a joke, that those "fins" hanging down would act as rudders. Don't worry about that.
You are taking a gamble with this car now, but I don't think it is a big one. Keep the speeds and such reasonable, keep proper spacing from other cars, then even if something does fail, it should be a non-tragic event. Those patch pieces are quite strong, but they are welded to rusted-out "quicksand"; and if there is rust like that there, then there are likely to be bad spots elsewhere, even in places you don't know about.
Old 10-25-2015, 06:17 PM   #9
ghawthorne
Lol, maybe I can weld on some longer steel and shovel people's driveways with my undercarriage.
Thanks Bill, and everybody else. I'll keep an eye on the quicksand and check the steel every time before I go out to make sure it's still in place. Fingers crossed we make it til April!
Old 10-26-2015, 01:55 AM   #10
el diablo viejo
1994 SW1
More like a keel if you will, and yes I was joking. The picture does not show the LCA bracket, which would be another critical area of concern if it was severely corroded. Otherwise, the repair looks like it should hold up well enough for what you need.
97 sl2 a/t 104 K
Old 10-26-2015, 08:48 AM   #11
westwind999
1999 SW1
If the subframe is rotted out there you need to carefully check the other points. The transmission mount, control arms, sway bar, are all important things that need to stay attached. If you feel comfortable that they are ok, some corrosion inhibitor might slow down the progression of the rust.
Old 10-26-2015, 08:58 AM   #12
billysvue
And we have a crystal ball from two pics and a descrip of a repair you expect us to render judgement?
Do you have life insurance? Do you have a will?
YOu make the call.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 10-26-2015, 04:37 PM   #13
If you or your friends are interested in swapping the front subframe
http://www.saturnfans.com/forums/sho...d.php?t=155369
Satty failed inspection :( Rotted subframe Midnight13 S-Series Tech 20 08-29-2012 07:04 PM
Will 1998 SW1 subframe fit 1996 SL1? Tommie S-Series Tech 5 08-24-2010 02:43 PM
Rotted subframe on driver's side... what to do?? aaron7 S-Series Mods 3 07-11-2009 09:22 AM
How to fit a subframe in the back of an s-series sedan. pimpin88 S-Series Tech 4 01-07-2009 01:42 PM
1998 sl2 cradle replacement(subframe) gman41 S-Series General 5 01-08-2006 01:56 AM
