Old 07-05-2014, 10:21 PM   #1
ROCCERO4
ROCCERO4 is on a distinguished road
Default Power Loss Shifting / Rlling When In a gear
Ok don't know if these two are related but, first my 97SL1 standard would end up in the street in the morning even though I parked it in my driveway which has a slight incline. What could be the cause ? Inwould always leave it in 2nd gear no emergency brake engaged
Secondly, I recently started noticing loss of power when putting it from 2nd to 3rd to 4th it would have a slight bucking to it and eventually when I had enough speed 5th which it seemed by then to have adequate speed 75-80 mph and no slight bucking. What 's up ? Any suggestions, hints would be appreciated.
ROCCERO4 is offline   Reply With Quote
Old 07-06-2014, 07:06 AM   #2
Pitcher
Pitcher's Avatar
Default Re: Power Loss Shifting / Rlling When In a gear
Always leave the car in 1st or Reverse gears when you park it. Also, pull up on the parking brake if it works.
Owned 4 other S-Series.
Old 07-06-2014, 10:31 AM   #3
The car rolled down the driveway because you refuse to use the parking brake on any non flat surface. Even leaving a car with manual xmission, the engine turns over ever so slowly despite engine compression. Either start using the parking brake or find your car creeping down hill.
Car mileage? A brief history of all maintenance and parts replaced? A compression test and reading about egr valves to use a temporary blocking basket may help troubleshoot one.
Old 07-06-2014, 12:49 PM   #4
1st gear for front end up, reverse for back end up. Any other gear for finding the car in the road later in the day/night.
Loss of power may be to do with your parking style forcing the engine to rotate the wrong way...
Old 07-06-2014, 05:37 PM   #5
westwind999
1999 SW1
Yes, use your hand brake. Don't put it on a little bit either or you might drive away with it still on.
99 SC1 Loss of Power and I'm at a Loss gwade12 S-Series Tech 1 05-10-2014 12:22 AM
lots of codes/ABS loss, power steering loss Burgandy25 Astra Tech 1 01-30-2014 05:34 PM
loss of power and hard shifting njhill L-Series General 1 06-28-2012 11:22 AM
sl-2 gear loss.... mchapman87 S-Series Tech 6 06-08-2011 10:56 AM
Electrical Power Loss From Shifting Gears? DecayingOmega S-Series General 8 06-27-2006 11:08 AM
