Old 03-10-2013, 02:26 AM   #1
PanVet
PanVet is on a distinguished road
2008 Astra XE
2004 VUE 3.6L
Default New wheels
So the time has come to replace the factory 15 inch wheels with some 17s.
I have been told that it will change the actual speed reading of the car and I will actually be going slower then what the speedometer reads.
Any idea how much of a difference 15s to 17s will make?
PanVet is offline   Reply With Quote
Old 03-10-2013, 11:48 AM   #2
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Default Re: New wheels
The diameter of the rim itself doesn't make a difference, unless you want to donk your Astra (not sure if that's a verb or not). What matters is the overall outside diameter (OD) of the tread of the tire. You can use an online calculator such as this one to judge the difference. All you do is enter your existing tire size, and then check below to see how those stats compare to various other tire sizes. You can set the percentage below to widen or narrow the range of results (compared to your original tire OD), and see the difference at a specific vehicle speed.
PS: If you want to jump up to 17" wheels/tires, you should know that the Astra tire size found on the factory 17" wheels is 225/45R17, and they would be an exact match to the 195/65R15 tires that I believe you are running.
PPS: The speedometers of nearly all cars tend to read higher than your actual measured vehicle speed when calculated by GPS or covering known distances (with BMWs apparently being the worst), so you can err on the "slightly larger than stock" side and still be reasonably on target. Just not too big, since large jumps can start to cause rubbing issues inside the wheel well on the plastic fender liner or on some suspension components. I can't tell you how much is too much, because it varies from car to car (as well as how you load the car up with weight, how aggressive you corner, etc.).
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Astra La Vista! is offline   Reply With Quote
Old 03-10-2013, 12:17 PM   #3
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Fyi, the factory wheels were 16, 17, or 18 inch. Nothing smaller fits over the upgraded brakes we got in NA. You probably have 16 inch wheels, not 15's. As was said already, the outside diameter of the tires don't change between the three rim sizes.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
emg77 is offline   Reply With Quote
Old 03-10-2013, 03:23 PM   #4
Tom S2
Tom S2 will become famous soon enoughTom S2 will become famous soon enough
Tom S2's Avatar
2008 Astra XR
the outside diameter of the tire on the astra is the same as BMW and Porsche. 25". I think the factory 18s came with a tire that was slightly different than 25", or was narrower than the 225s that came on the 17" rims in order to not rub and be a 25" outside diameter.
Astra XR-3-5 HP - Hamster Powered!
Dealer added options, & Infinity speakers.
Tom S2 is offline   Reply With Quote
Old 03-11-2013, 09:53 AM   #5
PanVet
2008 Astra XE
2004 VUE 3.6L
They are 16. I checked the label in the drivers door well.
Old 03-11-2013, 11:39 PM   #6
PanVet
2008 Astra XE
2004 VUE 3.6L
Hopefully this will be my last stupid question.
The tires measure 17x7.5 and the rims are the same measurement so I am assuming I can mount them together?
Old 03-12-2013, 08:06 AM   #7
romanster
romanster will become famous soon enough
romanster's Avatar
The stock tire sizes are:
205/50/16 for 16" wheels
225/45/17 for 17" wheels (at least mine were)
225/40/18 for 18" wheels
Stick with those dimensions when you're shopping around for tires and the spedometer will be unaffected. I decided to go wide with my 18's and got 245/40/18 tires, which bumps up the total diameter about 0.7". The tire calculators said this would make my spedometer read a bit slow (actual speed 102km/h when the spedo says 100km/h), but I'm fine with that.
Astra XR3 white
|Vauxhall VXR exterior conversion
|2010+ emblems
|Insignia VXR 18" rep wheels, Eibach SportLines
|BiXenon projector retrofit
|Blue interior LED conversion, OPC wheel/shifter
romanster is offline   Reply With Quote
Old 03-12-2013, 08:43 PM   #8
PanVet
2008 Astra XE
2004 VUE 3.6L
I heard some people had a rubbing issue when going with 18s. Which was why I was going with 17s.
Old 03-13-2013, 02:18 PM   #9
Astra La Vista!
2008 Astra XR
Shouldn't be a problem as long as the wheel has the same width and offset as the factory wheel, and you use the factory 225/40R18 size.
Looking for XE wheels / covers instead of XR wheels JW 4x4 Aura General 3 09-19-2011 04:12 PM
new wheels installed/stock wheels for sale mjmi11er 2008 Vue 1 09-18-2010 01:29 AM
4 wheels hub on s series change to 5 wheels hub RUTHORLAS S-Series Tech 6 07-25-2009 10:18 PM
New 16" wheels and tires need lug torque for aluminum wheels. scbackpacker S-Series General 4 03-05-2006 01:34 PM
92 SL1, 15/16" Wheels?!? Other GM Wheels? SyNNeR S-Series Mods 7 05-10-2002 05:28 PM
