Old 10-25-2012, 09:48 AM   #1
PanVet
PanVet is on a distinguished road
2008 Astra XE
2004 VUE 3.6L
Default Code P1101
Intake air flow system performance. The ECM detected that the actual air flow as measured from the MAF, SCIP and TP did not match the expect range for more then .5 seconds.
I am getting the check engine light and code P1101. Seems to come and go. Had it several months ago then went away. Got the CEL over the weekend then it went away yesterday. Came back today.
Is this something I need to be worried about? What is my risk factor?
Any ideas on a fix?
PanVet is offline   Reply With Quote
Old 10-25-2012, 09:25 PM   #2
vanilla sky
vanilla sky is on a distinguished road
2008 Astra XR
Default Re: Code P1101
Clean your MAF meter with some MAF meter cleaner. It worked on my car twice, although I'm considering replacing it. I found them fairly cheap if purchased in bulk, so I might look at setting up a group buy.
vanilla sky is offline   Reply With Quote
code P1101 after new intake Mil Astra General 25 10-05-2017 08:37 AM
I am replacing a bad ignition coil this week. Codes: P0304, P1101, P0496, P0068. Petroleum Astra Tech 2 06-29-2012 06:53 PM
P0410 code, changed ECTS, code back mattwithcats S-Series Tech 1 06-24-2011 07:40 PM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 10:26 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
