Old 10-10-2010, 09:29 PM   #1
donaldo1954
donaldo1954 is on a distinguished road
Location: Southwest Michigan, 100 yards from Lake Michigan
Default Flex pipe from downpipe to Catylitic
Attached is a picture of the front of the flex on a 1996 SL2 with around 125K miles. It looks like it's around another pipe inside. As you can see it's pretty much broken loose all around the front. Is this an issue I need to be concerned about?
donaldo1954 is offline   Reply With Quote
Old 10-10-2010, 09:48 PM   #2
fmctaurus
fmctaurus is a jewel in the roughfmctaurus is a jewel in the roughfmctaurus is a jewel in the roughfmctaurus is a jewel in the rough
fmctaurus's Avatar
1997 SL1
Default Re: Flex pipe from downpipe to Catylitic
My 97 SL1 with 164,600 miles has the same issue. I too am wondering about this.
fmctaurus is offline   Reply With Quote
Old 10-10-2010, 10:20 PM   #3
If it's not leaking, technically it's alright, for now. But it looks like it's not long before it rusts through and starts to leak. Tell-tale sign (aside from the leak itself) would be a P0420 code.
See that hanger with the bolt/nut just ahead of the flexpipe? Start nailing that, and the flange bolts at the catalytic and the manifold/downpipe with PB-B'Laster now. Repeat every now and then, until the time the flexpipe rusts through. That'll make removal of the assembly easier. You can replace just the flexpipe, weld it to the dowpipe and cat, but at this age, the cat is likely close to the end of its life, and replacement of the whole downpipe-flexpipe-cat assembly, as a bolt-on, would be most expedient.
Old 10-10-2010, 10:29 PM   #4
off-track
off-track's Avatar
Yeah, it's toast but.. Should you be concerned? Maybe not.. While the car is idling have a friend hold a rag over the exhaust pipe. Hover your hand around the joint and see if feel leaks. If so, the inner flex is cracked and it's just a matter of time till it falls apart.
Most here would recommend a whole new Walker direct fit downpipe/flex/cat. I opted for the local mexi-muffler shop just replacing the flex for $80 and it's fine for now. (didn't want to deal with the severely rusted cat bolts)
Purchased 114k 10/07
Added OEM CC
Old 10-10-2010, 11:28 PM   #5
Originally Posted by off-track View Post
I opted for the local mexi-muffler shop ....
Seriously? You went to that place at Park & Fish Hatch? And didn't roll out with a fart cannon and a set of 22's, and the car 3" lower?
Old 10-11-2010, 10:08 PM   #6
off-track
off-track's Avatar
Ok, you caught me! I don't have a torch myself so that wasn't an option. I really didn't want to do that but Car-X/Midas/Whatever quoted $300 for the exact same thing! Two years ago it was $120 for my son's flex + a few hangers. At that point in the rebuild I just wanted to cut my losses to a minimum.
When the cheap'o muffler fell off a few week later they replaced that as well for $50. Despite the displays, no fart can on this Sat! Did see one on a SL1 today.. I just shook my head.
Added OEM CC
Old 10-11-2010, 10:41 PM   #7
slowgls
slowgls is on a distinguished road
slowgls's Avatar
1994 SL1
Was it a 96 salmon colored car?if so i know that car.Yea i know kinda sad.
1999 Saturn sl2 DOHC 5 speed
slowgls is offline   Reply With Quote
Old 10-12-2010, 12:50 AM   #8
Dr. Sprock
Dr. Sprock will become famous soon enough
you need a Walker 44539 @ 109.79 rockauto.
or an AP 38579
Dr. Sprock is offline   Reply With Quote
Old 10-12-2010, 09:54 AM   #9
OnDaGround
OnDaGround's Avatar
1993 SC2
^^^ For that price I would opt for some aftermarket headers. Broken parts are always a good reason to go with performance replacements.
Saturnless...
Old 10-12-2010, 09:43 PM   #10
off-track
off-track's Avatar
Not sure who you were going with there ODG but.. to me Saturn <> performance by any standard. From my point of view, it's all about economy.
Added OEM CC
Old 10-13-2010, 10:06 AM   #11
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
that SS braid is just a protective cover which also helps it if it gets hyper extended, like bent too far., underneath is a spiral wound flexible SS pipe. so if it s not leaking, then dont worry.
sdowney717 is offline   Reply With Quote
Old 10-14-2010, 10:42 PM   #12
2000mc
2000mc is on a distinguished road
1999 SC1
exactly!
2000mc is offline   Reply With Quote
Old 10-16-2010, 09:49 PM   #13
ncpdsp10
ncpdsp10 is on a distinguished road
Don, I have a 1995 SL1 witn 140,000 miles on it now. Last week I took it in for NYS emissions inspection and was told it failed because of a leaky flex pipe. was told that the shop would repair it for $360.00, which I declined. The next morning I went to local auto parts store and bought two muffler patch kits 2" wide by 3' for $10.00 and rapped both joints at each end and clamped a 2.5" stainless hose clamp over it on each end. Brought it back to shop and had a redo on emissions inspection and the car passed.
ncpdsp10 is offline   Reply With Quote
Old 10-16-2010, 10:25 PM   #14
Chazberry
Chazberry's Avatar
1995 SW2
My story almost exactly ('95 SW2 - same mileage). Except I replaced the flex (MAJOR PITA). Should have just gotten a Walker 52166 . . .
http://www.saturnfans.com/forums/att...7&d=1285879756
need new flex pipe PlasticCarsRock S-Series Tech 5 04-11-2008 09:16 PM
91 SL2 Flex Pipe keith122 S-Series Tech 11 03-29-2008 06:56 PM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 04:46 PM
FS: 95 SL1 SOHC Flex/Downpipe e_a_olson Classifieds 1 08-01-2006 11:39 AM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 08:44 PM
