Old 08-13-2010, 04:54 PM   #1
Dennis6
Dennis6 is on a distinguished road
Default Steering Wheel Noise 2008 and up Vue
This post is to provide information about this problem for 2008 and up Saturn Vue,so please use the information if it helps(no opinions,stories,ect.)
I took our 2008 XE in today for warranty work.
I was noticing a whirring or whoosing noise coming from the steering wheel when turning the wheel all the way left or right,and also a slight grinding sound.
What they did was put in a new steering gear part#19180762,flushed and filled the power steering pump and finally a front end alignment.
This took care of the problem.It is apparently a common problem,and they knew exactly what it was.
Dennis6 is offline   Reply With Quote
Old 08-14-2010, 08:36 PM   #2
hand-filer
hand-filer is on a distinguished road
2008 VUE Red Line
Default Re: Steering Wheel Noise 2008 and up Vue
Thanks for the info.
hand-filer is offline   Reply With Quote
Old 09-14-2010, 09:39 PM   #3
fanto3k4
fanto3k4 is on a distinguished road
We had the same issue and they did the same repair about 6 months ago. We took it back because it was making noise again. They said the had to grease the boot going through the firewall. Wife drives it home and now there is air noise coming into the cab. I look at the boot and it appears ripped. Can I get someone to take a pic of theirs and post?
I found this notice 09-08
Vue -- Squeak while turning steering wheel
Modify boot, install new I-shaft bolts
Don't lubricate or replace I-shaft
09-02-35-00
fanto3k4 is offline   Reply With Quote
Old 09-15-2010, 04:59 PM   #4
neilpilot
neilpilot is on a distinguished road
2008 VUE 2.4L
My 2008 XE is electric power steering. Since the OP does not specify his model, I need to ask if this advisory only applies to the hydraulic PS system.
neilpilot is offline   Reply With Quote
Old 09-16-2010, 03:09 PM   #5
yankeefan10
yankeefan10 is on a distinguished road
yankeefan10's Avatar
2008 AURA XE
2008 VUE 3.6L
Thumbs Up Re: Steering Wheel Noise 2008 and up Vue
Wow! What a coincidence. I'm bringing in the VUE tomorrow for that exact problem. Thought I'd get on this site to see if any info. I really haven't been here for quite awhile, especially after I sold my 'hotrod' ION and bought an AURA for me. The ION was beating up my back, and had become a cop magnet. I live in an older community and my car just did not fit. Anyway, thanks for info. Taking it to our local approved Chevy dealer for us "orphaned" Saturn owners.
2008 AURA XE
Chrome accents inside and outside
Powered Bazooka subwoofer
Light Burlwood dashkit
Footwell lighting
P.A.L. for IPOD
18" AR Black w/ Chrome rings
2008 VUE XR
Real nice stock
yankeefan10 is offline   Reply With Quote
Old 09-22-2010, 02:33 PM   #6
hand-filer
2008 VUE Red Line
Apparently the above mentioned gear replacement pertains to the 3.5 engine only.
Do let us know what your diagnossis is.
Thanks,
H-F
Old 10-06-2010, 01:34 PM   #7
Way2QWK
Way2QWK is on a distinguished road
the steering rack replacement due to rubbing noise is for the hydraulic steering only. 3.5 and 3.6 engines
***Saturn Tech and owner of Planet Automotive in Tucson AZ. Specializing in Saturn repairs.
94 SW2- custom intake and ported throttle body
2003 Saturn Vue 3.0 v6
Way2QWK is offline   Reply With Quote
Old 10-06-2010, 07:54 PM   #8
hand-filer
2008 VUE Red Line
Periodically and just after start up my steering (I suspect the pump) will make a groaning sound after start up. You can also feel a slight shudder through the steering wheel if you move it left to right. It goes away after a minutes or two. I wonder if the pump is cavitating.
It is very intermittent so I haven't taken it in yet for diagnosis. My bumper to bumper warranty expired lat month.
Old 10-07-2010, 09:35 PM   #9
jgold47
jgold47 is on a distinguished road
09-02-35-00
Anyone have any thoughts on what the I-shaft bolts are? Fiance's 08 has started squealing when turning and its out of warranty. I will take a look at it, but curious what that is.
jgold47 is offline   Reply With Quote
Old 04-12-2011, 08:24 PM   #10
fanto3k4
My wife's Saturn is now on its 3rd steering gear. The car only has 24000 miles on it.
Old 07-04-2011, 07:18 PM   #11
musicman2240
musicman2240 is on a distinguished road
Your information was right on thanks.
musicman2240 is offline   Reply With Quote
Old 07-04-2011, 07:22 PM   #12
musicman2240
Your information was right on. My used 2008 vue redline started to do the samething at about 40,000 and I still had time on my certified warranty. I of course had to take it to a chevy dealer and I used your words plus the description of "rubbing" as well, at first they acted unsure of what the problem was but then ended up replacing the steering gear and it took care of the problem.
Thanks for your post.
Old 07-26-2011, 08:24 AM   #13
Buggerall
Buggerall is on a distinguished road
Which warranty is this repaired covered under?
Buggerall is offline   Reply With Quote
Old 09-12-2012, 04:03 PM   #14
Tmost64
Tmost64 is on a distinguished road
I have a 2006 Vue with the same steering column rattle. I was told by A Chevrolete dealer repair center that I needed a new steering column for $1500.00. I t seems to me that something should be abl to be repaired or replaced before we get to the steeing column! Any thoughts?
Tmost64 is offline   Reply With Quote
Old 01-31-2013, 09:35 AM   #15
Mystic_Cobra
Mystic_Cobra has a spectacular aura aboutMystic_Cobra has a spectacular aura aboutMystic_Cobra has a spectacular aura about
2000 SL2
Found several posts here regarding a steering squeak. Seems like a common issue for the Saturns - all models.
Mystic_Cobra is offline   Reply With Quote
Old 02-01-2013, 11:27 AM   #16
neilpilot
2008 VUE 2.4L
Not true - only applies to hydraulic steering racks. I believe all 4-cyl VUEs are electric, and exempt. No apparent problems with my steering.
Old 02-01-2013, 03:00 PM   #17
Mystic_Cobra
2000 SL2
Good to know, thanks!
Old 02-01-2013, 03:03 PM   #18
Mystic_Cobra
2000 SL2
How do you like the electric assist, by the way?
Old 02-01-2013, 03:50 PM   #19
neilpilot
2008 VUE 2.4L
As I said, I've had no issues in my first 5 years & 76k miles. I really can't detect much difference in performance, but I've never driven a v6 VUE with a traditional steering rack.
Old 07-16-2013, 05:34 PM   #20
mrobinson92
mrobinson92 is on a distinguished road
Having same problem. With the number of posts, is there a service bulletin or recall on part? Got raked for a power steering pump that didn't correct the problem. Live in Delaware. Anyone know someone who is familiar with the problem and can fix it correctly?
mrobinson92 is offline   Reply With Quote
2003 Vue Steering Wheel Tunk Noise When Turning Wheel kencat Vue General 6 03-05-2010 07:06 PM
rubbing noise steering wheel/steering column on 04 Vue ynotps Vue General 6 03-03-2005 08:59 PM
Steering Wheel Noise shawgod Ion General 3 05-10-2004 09:02 PM
Steering wheel noise sdaniel75 L-Series Tech 4 09-13-2003 02:34 AM
Steering wheel noise! jackhammer Vue General 10 07-31-2003 08:00 PM
