Old 11-13-2008, 01:46 AM   #1
sl2gold
sl2gold is on a distinguished road
sl2gold's Avatar
Default A slightly different vibration question
I've got this slight shimmy with a slight bounce in the front from 60-65 mph that disappears again after about 70 mph, I've repalced the rotors, had Les Schwab do a wheel alignment and check the front end, the tires have been balanced over and over again and I even swapped the front wheels to the back but I can't figure it out. I think they may have checked for bent rims but I don't remember. Anyway, I'm at my wits end. My question is, besides what could be causing this, if I lower the car later, will it get worse ?
sl2gold is offline   Reply With Quote
Old 11-13-2008, 11:27 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: A slightly different vibration question
Check the tires and see if there is an uneven tread wear on them. Check the wheel bearings and check the control arm bushings. Also check your sway bar links.
Saturnless...
Old 11-14-2008, 01:06 AM   #3
sl2gold
sl2gold's Avatar
Okay, I'll need to get those checked, but as far as lowering the car, will it get any worse if I can't find the source of the vibration ??
Old 11-14-2008, 08:36 AM   #4
OnDaGround
OnDaGround's Avatar
1993 SC2
I'm sure if you have all those checked you will find it. I cannot really imagine lowering it would make it worse, maybe more noticable.
Saturnless...
Old 11-14-2008, 08:43 AM   #5
72gssaturn
72gssaturn will become famous soon enough72gssaturn will become famous soon enough
72gssaturn's Avatar
2008 Astra XR
wheel bearing or bent half shaft?
Gerry
72 Buick GS red
2008 Astra XR black 3dr
99 SL1
72gssaturn is offline   Reply With Quote
Old 11-14-2008, 08:45 AM   #6
OnDaGround
OnDaGround's Avatar
1993 SC2
check tie rods for the hell of it, but I would be willing to bet its the wheel bearing.
Saturnless...
Old 11-16-2008, 03:20 AM   #7
sl2gold
sl2gold's Avatar
So the wheel bearing could be causing the slight bounce as well as the wobble and could it cause it do to do it only at certain speeds ??
Old 11-17-2008, 01:30 AM   #8
Canyon
Canyon has a spectacular aura aboutCanyon has a spectacular aura about
1999 SL1
When you feel this bounce or shimmy if you let off the gas does it go away? I am trying to rule out the CV shaft. If you have a standard you can just disengage the clutch. On an auto, shift into neutral.
Here is how to check out the front suspension components. Jack up the front wheels. Grab the top and bottom of the wheel and gently rock it top to bottom. If you feel play it is either the lower ball joint or the wheel bearing. Next, grab the two sides and gently rock it back and forth. If you feel play the tie rod is likely bad. When you do it side to side don't mistake moving the wheel so much that you are actually moving the steering wheel for a bad tie rod end. When I do this I look at the steering wheel to make sure I'm not moving it.
Because of the way the Saturn's are built, it is difficult to feel the play in the ball joint because of how the sway bar goes though it and pushes it up. They are pretty easy to replace so if I suspect they are bad I just replace them. If the rubber is torn then I would just go ahead and replace them. You're going to have to do it anyway.
Canyon is offline   Reply With Quote
Old 11-17-2008, 02:00 AM   #9
sl2gold
sl2gold's Avatar
[QUOTE=Canyon;1349228]When you feel this bounce or shimmy if you let off the gas does it go away? I am trying to rule out the CV shaft.
It only shimmies/bounces when Im on the freeway at about 60-65 mph, when it gets to 70 it seems to smooth out. I'm pretty sure it'll vibrate at that speed whether I'm on the gas or not.
Old 11-17-2008, 08:57 AM   #10
OnDaGround
OnDaGround's Avatar
1993 SC2
I would check to make sure the tires are not more worn on the inside than out. That would cause you to only feel it at certain speeds.
Saturnless...
Vibration Question AQuinn19 S-Series Tech 7 09-17-2009 05:04 PM
Question about the vibration others have mentioned Nittany Lion Aura General 14 10-31-2007 09:48 PM
Cold Vibration Question ghack S-Series General 2 11-04-2006 05:31 PM
Vibration question NCtim Vue Tech 8 04-30-2006 12:09 AM
L300 Vibration Question RustyJCNC L-Series Tech 16 10-17-2002 03:25 PM
